Sponsored by: Real Truck
Gas vs PSD
Old Jun 24, 2010 | 02:13 PM
  #5461
Jrfish007's Avatar
Jrfish007
Originally Posted by Jrfish007
My post in summary was: An engine with no torque will need massive gearing and/or tranny to make it move a heavy load and this become problematic at high speeds because of that gearing.
We see this all the time. At 70 RPM my V10 is at 2500 rpm with a 4.30 while a newer 6.4 maybe only at 1800 with it's 3.55 rear end. Now if you take a torqueless engine like the rotary, you'll have to run some stupid rear end to be able to move the truck + a 15-20k lb load. Lets just say that since it has about 1/4 the torque of the V10, it would need 4 times bigger rear end, that means we'll be running 13.2 rear end to put the same amount of torque to the tires to get everything moving as my V10 would have (same trannies).
that's fine and all, but what about at 70 mph? While my V10 is at 2500 or so, the rotary will be at 4 times that, or 10,000 RPMs. Same thing when you compare the V10 to the PSD, the more aggressive gears in the gasser that help it get the starting power, are a disadvantage by keeping the RPM's high at highway speeds. I just metnioned the 7.3 PSD because they were similar in hp.
The major difference is that the V10 is practical and usable while the rotary engine is not.
Let me take 1 more crack at this:
The 7.3 PSD and rotoray engine both having 250 hp can technically put down the same force to the ground (rather it be tractile force or rear wheel torque), but they can not do the same job. One can do it with reasonable gearing that allows to start pulling the load and pull it at highway speeds. The other engine can pull the load, but the gearing becomes so steep it can not pull the load at highway speeds.
So if the job is to get a load going and pull it down the highway at highway speed (i.e. at least 70 mph), there is a problem with the rotary engine. Why? because it makes it's power at to high of RPM's and requires massive gearing where as the diesel can make it's power at lower RPM's. See the resemblance to the V10 and PSD now? The V10 also makes it's power at higher RPM's than the PSD. Yes, the V10 makes quite a bit of power at low RPM's compared to other gas engines, but not compared to what a diesel engine can do (go back to my other stupid long posts for the chemical reasons why).
Old Jun 24, 2010 | 02:16 PM
  #5462
Jrfish007's Avatar
Jrfish007
Originally Posted by Rush117
The reason it is not technically interchangeable is because you are using pound/feet as your unit. There are only 2 ways, that I am aware of, where pound feet can be used at the rear. One is if you are referring to "axle torque". The other is if the truck has 24" tires, thereby rear wheel torque (in pound/feet) and tractive force would be the same number, disregarding the coefficient of traction of course.
I know what you're saying though. It's basically semantics and you'd need a heavy duty pocket protector and taped together black birth control glasses to really care either way. For the record, I don't care either way I was just wondering how long it would take for tractive force to be mentioned.
At that point is just a conversion factor that takes into account your tire size. That is just throwing a skid full of bullets into a fire though.
Old Jun 24, 2010 | 02:18 PM
  #5463
Jrfish007's Avatar
Jrfish007
Originally Posted by Lead Head
There are CVTs that can take that kind of abuse, but you don't see them in the automotive environment because they usually take up a lot of space are are far too noisy
There are plenty of hydrostatic transmissions that are upto the task though. Hydrostatics have a near limitless "low gear" range. You could be bouncing off the rev limiter at 5500RPM and still be crawling at a quarter mile per hour.
Interesting, I don't really follow transmission stuff outside of the auto industry, so I have no idea. I know my lawn mower has a hydrostatic
Old Jun 24, 2010 | 02:30 PM
  #5464
02GrayPowerStroke's Avatar
02GrayPowerStroke
Originally Posted by phillips91
What were the set ups for your 5.4 and 7.3?
4.10 on the 5.4, 3.73 on the 7.3, and 4.10 on the 6.0
Old Jun 24, 2010 | 03:17 PM
  #5465
phillips91's Avatar
phillips91
What kind of trannys? What year was the 5.4? Cab sizes? F-150, 250?
The reason why I am asking about the tranny is that, like mentioned before, 97% of SD's are automatics. So chances are people who are comparing the different engines are comparing both of them with automatics. "IF" your 5.4 was an auto and a 2v(like mine, and comparable year to the 7.3) and "IF" your 7.3 is an auto, to save everyone the math, at 2k rpm the tractive force of your 5.4 would have been 3,482 and the tractive force of your 7.3 at 2k rpm would be 5,305. They wouldn't even be close when it comes to getting a load moving. Chances are, with a big enough load and hill, your 5.4 would never see peak hp rpm.
By comparison, my manual is putting 7,415 to the ground in 1st at 2k rpm and 7,112 by 4,500 rpm. Compare that to a 6.4 with a 3.55 and ts. At 2k rpm the 6.4 is putting 7,196 to the ground and at 3k rpm it is putting 6,758 to the ground. So in a race from a dead stop to 4,500 rpm in mine I have no doubt it would be ahead of the 6.4. Shifting to 2nd, 3rd and so on the 6.4 would run off and leave me in the dust, but I am just talking about getting the load moving(0 to ~25 mph).
Old Jun 24, 2010 | 03:21 PM
  #5466
Kajtek1's Avatar
Kajtek1
Ever hear of the Bugatti Veyron? They ran that engine full out for days before releasing it. Not to mention it has 10 radiators.
The VW Pheaton was also designed to run at 90% maximum power with an ambient outdoor temperature of 130F while maintaining an interior temp of 72F for a minimum of 4 hours.
It's all about cooling, an engine can run at 100% output forever if you provide the proper amount of cooling. As for the V10, I'm not sure because I don't live there, but I bet that radiator which is as big as a 3rd world house can handle some heat.
You don't know much about Buggati Veyron do you?
Running at redline the tank of fuel in the car last for about 1/2 hr
Wouldn't that be 40 minutes shorter than in Bill's van?
Sad part is, that technicality any gasoline engine is way more of the heater than an engine. Only about 1/3 of gasoline is converted into HP. And that is for the most efficient engines, what V10 is not
Now show me a pickup with 10 radiators?
Old Jun 24, 2010 | 04:44 PM
  #5467
bill11012's Avatar
bill11012
Modular motor junkie
I am sure it could pull any load that a PSD could. But how effective and efficient would it pull it? Just wondering.
It would be every bit as effective, but not as efficient.
You ever try to type an exclamation point using only your nose?
tractive force is what I'm talking about. The only real difference between wheel torque and tractive force is that if you put down to much wheel torque, you will spin your tires and loose tractive force. I'm assuming we are all adults here and don't do that though
Of course not.
Originally Posted by Kajtek1
I wonder how Bill's van would hold 6000 lb on the bumper?
I have put 6k over the back axle, but lets not try it on the bumper.
I drove the set on the picture above on Nevada desert keeping the engine close to redline for about 20 minutes when I was climbing the big mountain at 90F outside.
Not only the engine didn't overheat, but I was using AC at part of the time.
If there is a gas engine that can match that performance, I would like to see it.
The V10 can do that just fine. It has no problem running WOT for long amounts of time right at peak HP. I never turn off the A/C pulling.
You must be driving gaser
The truck pulled the weight just fine and I drove the I15 from Vegas to LA where there is a famous grade with lot of spots with burned asphalt on the shoulder.
How steep is the grade?
Very simple.
V10 owners have NO IDEA what PSD are capable to do
I know what a PSD can do. There is one on Youtube pulling an 80' mobile home. My V10 could do that too though.
Old Jun 24, 2010 | 06:20 PM
  #5468
kx450frider617's Avatar
kx450frider617
Why doesn't some one just get together all the engines of the same years and hook up identical trailer up a hill and see who wins.
Old Jun 24, 2010 | 06:41 PM
  #5469
bill11012's Avatar
bill11012
I am game for that.
My 01 will out pull any stock truck ford made before late 03.
With its gearing it can out pull the averge stock 3.73 auto 6.0 too.
Old Jun 24, 2010 | 06:45 PM
  #5470
Sand_Man's Avatar
Sand_Man
Already been done, and not surprisingly, the diesel did it the best. There is truly no denying that when it comes to heavy towing, turbo diesels are great at towing. But some people contend (I'm one of them) that the extra initial cost, coupled with higher maintenance costs and greater repair costs aren't enough to justify owning one. I am well aware of the fact they tow better, get better mileage and so on, but it only takes one $10,000 repair bill to wipe that out. I also am fully aware that most diesel trucks are trouble free, and even more so when they are maintained well. But a quick look through any of the diesel-specific threads on this forum will prove my point that IF a diesel breaks, it sure as heck ain't free to fix!
Old Jun 24, 2010 | 06:52 PM
  #5471
phillips91's Avatar
phillips91
A few if us have made videos of our pulls and compared them, but it's hard to get much from that because of different elevations, climbs, road conditions, etc. A few guys got together and pulled the same hill with the same trailer, but even that was tricky. It was close to the worst set up possible for a v10 (2v, automatic, 3.73 gear), the 7.3 either wouldn't downshift or it was already turning too many rpms to downshift. The v10 couldn't get the rpms up in the powerband on the steep part, but it went 1-2 mph faster than the 7.3 on that section. Once the hill leveled off for a stretch the v10 got its rpms up and made the next part of the climb at pretty much the same speed as the 6.0/6.4.
I got my 5.4 on a much shorter and a little steeper hill with ~the same weight trailer and was 8-10 mph faster than the v10 and 7.3 when I ran out of road. With an automatic I probably would have been 8-10 mph slower than them though.
What I would like to see is a stock 3v v10 with a manual and 4.10 gear against a stock 6.0 or 6.4 with an automatic.
Old Jun 24, 2010 | 07:01 PM
  #5472
bill11012's Avatar
bill11012
It has never been done with an 05+ V10! They used a 00-04 V10 vs a 6.4.
Old Jun 24, 2010 | 07:04 PM
  #5473
Tom's Avatar
Tom
I would go further than that and say I'd like to see a 6.0L/6.4L auto and manual run in a similar test as to what we did in Millersburg. I'm pretty confident the 5R110 would put a hurtin' on the ZF6 on a very steep grade for two reasons.
Turbocharged engines need time to build boost, and every time you shift you'd have to build boost all over again. The auto can shift with power being applied so there's no lost boost.
Secondly, the torque converter makes launching that much weight on a grade a stupidly simple affair. Mash the go pedal, release the stop pedal, and away we go. No burnt up clutches, no stalled engines, just seamless power.
Old Jun 24, 2010 | 07:15 PM
  #5474
bill11012's Avatar
bill11012
We agree on most things, but I disagree about this.
If done right power shifting will keep you from losing boost.
Its harder to do, but done right you can launch a ZF5/6 much faster than a TS.
Should only burn the clutch if its done wrong.
Old Jun 24, 2010 | 07:25 PM
  #5475
Sand_Man's Avatar
Sand_Man
Power-shifting a ZF???? I'd say that's a recipe for disaster if there ever was one, let alone under a load.
