Sponsored by: Real Truck
Gas vs PSD
Old Apr 29, 2010 | 09:47 AM
  #4111
ehgeeray's Avatar
ehgeeray
I always come read this post every time I'm looking for a good laugh... It just keeps getting funnier as the time goes on.
Old Apr 29, 2010 | 10:03 AM
  #4112
pappy19's Avatar
pappy19
Good real world tests on those videos. Too bad there wasn't a 2006 or newer V-10 with the 3v and Torqueshift tranny with a stock 4.10 rear against those diesels. Against the 2006 6 leaker and 2008 6.4, the old V-10 still wasn't all that far behind. With the newer HP V-10's, I doubt that there would be much difference between the 6 leaker, 6.4 sootbag and the studly V-10. If anything the V-10 would be king of the hill due to the time it takes the diesel turbos to wind up and be effecient.
Pap
Old Apr 29, 2010 | 10:10 AM
  #4113
Tom's Avatar
Tom
Yeah, we were hoping someone with a 3V V10 would be able to make it, but no such luck. The biggest problem Mike's V10 had was the 4R100 transmission's tall 1st gear as well as the huge spacing between 1st and 2nd gear.
I have do disagree about your reasoning why the 3V would have been faster, though. My "sootbag" takes between 1-3 seconds to build boost and start making serious power. Did you see in the first video how long it took between when I applied full power and the wheels broke loose? It would take the V10 much longer to climb into the RPM range it needs to make that kind of power with that much weight on a steep hill.
Old Apr 29, 2010 | 10:24 AM
  #4114
pappy19's Avatar
pappy19
I will admit that of all the new diesel trucks, the Ford 6.4 is the closest to staying with or maybe beating the newer V-10's towing up hills. In my experience here in the west, I have been challenged by every new diesel truck out there on one hill or another. The new Chevy's and Dodges are easy to whip and I have just about stayed even with the 6.4's. Of course I have not had the opportunity to tow the same trailer on the test you all did, but I have towed an overloaded 16' utility tandum trailer all over Idaho, Utah, Arizona and New Mexico and it has never had a problem keeping speed. I think the difference in the rear ratio's from the V-10's 4.10 and the new 6.4's with the 3.55 would be real evident in towing. The 3.73's would keep it closer but most all of the new 6.4's that I have seen are coming from the factory with 3.55's to help their mileage, but will hurt their pulling and towing ability.
Pap
Old Apr 29, 2010 | 11:37 AM
  #4115
Tom's Avatar
Tom
I think the difference in the rear ratio's from the V-10's 4.10 and the new 6.4's with the 3.55 would be real evident in towing. The 3.73's would keep it closer but most all of the new 6.4's that I have seen are coming from the factory with 3.55's to help their mileage, but will hurt their pulling and towing ability.Pap
Honestly I'm not sure. The 6.0L and 6.4L engines have a pretty wide sweet spot as far as making power. Peak torque is at 2,000 RPMs an peak HP(at least 6.4L) is at 3,000. The TorqShift has no trouble placing the engine between 2500-3,000 RPMs during WOT at any speed. So gear for gear the rear end gears would make a small difference, but the 3.55s would be able to hold gears a bit longer so I suspect there would be very little difference at WOT.
I think there would be a difference cruising on the highway, though. My 3.73 gears are part of the reason that at 19,500 lbs towing to WI my truck very rarely had to downshift. It was able to pull all but the steepest hills in overdrive, which was nice because the transmission rarely had to shift. 3.31s or 3.55s may have forced it to downshift a bit more often, but I suspect it would have still handled the load pretty well.
Mike's V10 truck that we tested that day has 3.73s. That combined with the 4R100 transmission meant that it had a very tough time getting going in 1st gear. In this situation his truck may very well have done better if it had 4.10s. Because of the amount of weight and hill we were pulling his V10 never was able to rev past 3,000 RPMs, but it was VERY close. That extra gear reduction may have been enough for it to continue accelerating in 1st gear. Somehow I doubt Mike would be willing to spend the money to change to 4.10s simply to prove a point, however.
Old Apr 29, 2010 | 12:00 PM
  #4116
phillips91's Avatar
phillips91
What are you doing in WI?? Did you move and not tell us about it?
Old Apr 29, 2010 | 03:57 PM
  #4117
Seven-Point-Three's Avatar
Seven-Point-Three
"Too bad there wasn't a 2006 or newer V-10 with the 3v and Torqueshift tranny with a stock 4.10 rear against those diesels." - Yeah, somebody's gotta be the bottom Hopefully more real world tests get put together.
Old Apr 29, 2010 | 05:26 PM
  #4118
bill11012's Avatar
bill11012
Modular motor junkie
Your 7.3 would be trashed in a test with a 3V V10.
Old Apr 29, 2010 | 05:31 PM
  #4119
bill11012's Avatar
bill11012
Originally Posted by nmocean
I have a v10 now my friends have 7.3, 6.0, and the twin turbo. They have all been surprised by my v10, as a matter of fact I just whipped a Dodge cummins yesterday that had a chip pretty bad with the v10. I don't know which is better but I have driven them all and the best in my book is the 7.3. the 6.0 blows head gaskets on a constant basis and the twin turbo I just drove over the week-end towing and by itself was disappointing to say the least, my v10 has more ***** than that motor. The 7.3 motor is getting 21-23 mpg, the 6.0 and twin turbo is around 11 and my v10 gets 16.7 all the motors have the same gears 3.73. So I don't know but I am happy with mine.
Sounds like that 6.4 was sick. Your PI V10 has 310HP and the 6.4 should have 350.
  #4120
bill11012's Avatar
bill11012
Bill, I think it's getting fun again!
Yep.
Old Apr 29, 2010 | 06:08 PM
  #4121
Seven-Point-Three
Lets just say I doubt it. You're putting a lot of faith behind the 3V V10's HP. When pulling heavy give me torque all day, every day.
Old Apr 29, 2010 | 06:37 PM
  #4122
Tom's Avatar
Tom
Yeah, just got up here a week and a half ago. That's why we met in Millersburg for that comparison that weekend, as that was the last weekend I was in the state.
I changed jobs, went from inactive to AGR with the Army Reserves. I'm a recruiter now!
Old Apr 29, 2010 | 06:41 PM
  #4123
Old93junk's Avatar
Old93junk
I thought Josh's mom put an end to this thread?
Old Apr 29, 2010 | 06:50 PM
  #4124
Tom's Avatar
Tom
I just looked at the videos again to be sure. Your prized 7.3L engine never got above 26 MPH the whole way up the hill. Mike's 2V V10 while running the stock tune stayed between 35-40 MPH once it cleared the steepest part of the hill.
A 3V V10 with it's 5R110 transmission would have left the 7.3 like it was standing still. Have you driven all 4 engines up a hill with the same trailer? I have. I was the one driving in most of those videos. The PSD was much LOUDER with it's straight pipes and stacks, but the V10 pulled harder.
Really was a shame we weren't able to try that 7.3L with the chip turned up. Would have either gone lots faster or blew up the engine with high EGTs...
Old Apr 29, 2010 | 07:53 PM
  #4125
mountaineer27's Avatar
mountaineer27
as soon as im finished with my medical discarge ill take you up on the v10 vs 7.3. im gunna be driving cross country with my gooseneck. im gunna put the stock injectors back in for the trip. plus i have the 6 pos chip with stock as a setting. i just find it really hard to beleave that the 7.3 could only get 26 mph. what was the gearing in the trucks? yes i do believe it. i saw the video, just doesnt make any sense.
