Sponsored by: Real Truck
Gas vs PSD
Old Jun 25, 2010 | 08:06 AM
  #5521
mountaineer27's Avatar
mountaineer27
if you were smart you would not by a brand new truck for a work truck.
Old Jun 25, 2010 | 08:17 AM
  #5522
Jrfish007's Avatar
Jrfish007
Originally Posted by Krewat
Which is great, when you are using your truck to make money, to have the truck in the dealer's shop for two weeks. While the repairs are free, losing business because of a down truck is not something most people can deal with.
Which again is why lots of utility companies (and LIPA and National Grid are not small companies), contractors, you name it around here have gotten smart and are using gas engine powered F450/550's. I've actually spoken to some fleet managers around here, and the diesel's complexity scares them. Rightfully so.
I talked with a guy that owns a towing company here in town, he has 12 tow trucks and said the same thing. After buying one of the first 6.0's and having it down all the time he went to the V10. He said the mpg was only about 2 mpg better than the V10 (we're talking F550 with a 4.88 rear end in stop and go mountain traffic) so there was no real reason to get the diesel. He said he bought the 6.4L when it came out too and still wasn't impressed enough to go away from the V10. He said his next truck will be the 6.7, but he's still not it's good enough to stray from the V10. As he pointed out, anything goes wrong in the engine, the entire turbo setup will have to be pulled to get to the engine. He said the V10 rarely breaks, and when it does it's normally cheap and quick to fix compared to the diesels.
I guess turbos have their advantages and disadvantages.
He did say he still had a few 7.3's left, but they where getting worn out (more so the truck than the engine).
Old Jun 25, 2010 | 08:21 AM
  #5523
Jrfish007's Avatar
Jrfish007
Depends... If you need that truck to be dependable and reliable, you buy it new thinking will be exactly that, dependable and reliable. Which for a big company (or even a small company), that is what they need.
What if your power went out, and the power company told you they'll fix your power as soon the Ford dealer fixes their 5 year old 6.4 cab-lifter?
If you are referring to a work truck as a truck to go out into the fields with, then yes I agree with you.
Old Jun 25, 2010 | 08:28 AM
  #5524
Rush117's Avatar
Rush117
Originally Posted by Crazy001
And then subtract the $5-7,000 difference in purchase cost between the V10 and PSD of whichever year you're comparing and then see who wins!
This has been an argument against the psd since the beginning of the thread. The psd option DOES NOT depreciate to zero the moment it drives off the dealer lot. There is going to be an asset cost associated with the ownership of a psd, but it is not equal to $5,000 to $7,000 option cost unless you keep the truck for a LONG time. If an owner sells the truck in three years, he'd get back a majority of the initial cost.
Old Jun 25, 2010 | 08:30 AM
  #5525
mountaineer27
yes a work truck is just that. not a company truck to run errands in
Old Jun 25, 2010 | 08:36 AM
  #5526
Johnny Langton's Avatar
Johnny Langton
I'm pretty sure he was referring to farm type "fields", not running a work/service truck. As a "fleet manager" I'll tell you right now, buying used trucks that are out of warranty for use in a work environment is ignorant and costly. We at one time, averaged well over $5K month in repair costs for our fleet. Since we started buying new trucks/vans 4 years ago-it has slowly dropped to nearly nothing. We only have a few trucks left in our fleet that are older than '05-mine being one of them. Our only real costs right now are maintenance and consumables (tires,batteries,etc).
JL
Old Jun 25, 2010 | 08:43 AM
  #5527
Jrfish007's Avatar
Jrfish007
JL
Yes, but the previous post he was referring to was talking about fleet trucks, hence the confusion.
Old Jun 25, 2010 | 08:52 AM
  #5528
Jrfish007's Avatar
Jrfish007
You will also have to pay interest on that diesel. And yes you may recover a large portion of the cost, there something to be said for an option that is more than 20% of the MSRP of the truck.
Secondly, if the diesel looses anything, that is money lost that I did not need to loose. Take my examples I've mentioned in the passing: "that $7k looks a lot better in my 401k than my driveway." In one year since I bought my truck my 401k has went up 5% (was up 10%, but the market dropped down again). That diesel would have lost at least $500 worth, if not more now that the 6.7's are out.
Finally, you vehicles worth is never a guarantee. Lets say you keep your 6.4 for 5 years. In the mean time the 6.7 has proven to be a great engine. All the 6.4 cab lifters get traded in for 6.7's before there warranty runs out. The price of the 6.4's plummet because everyone wants the 6.7. That's just one example, there are many things that can affect resale.
IMO it's best to put the least amount into an uncertain and depreciating investment as possible. Hence the reason I got the truck with only the option I thought I absolutely needed or could not live without (i.e. CD player and cruise control).
Old Jun 25, 2010 | 09:11 AM
  #5529
strokin'_tatsch's Avatar
strokin'_tatsch
If you gear them correctly
Of course, one is not meant to be sitting there at peak torque for long periods of time, and the other is.
I would venture that a V10 IS meant to do that.
And again, this thread is about V10 vs. PSD - so throwing 250 HP rotary engines into the equation is, again, comparing apples to oranges
comparing a V10 gas to a V8 turbo DIESEL is also comparing apples to oranges. y'all aren't even comparing 2 trucks with the exact same gearing/tire size... I'm ok with that b/c a diesel will always be superior to a gasser when it comes to pulling. and then you throw mileage in on top of that and it's even more superior. Wonder why absolutely NO big rigs use big gas engines to pull large loads... cuz they would get horrible mileage perhaps???? Mind telling me exactly why torque doesn't matter??? torque in most cases isn't as important as horsepower when your at speed. remember horsepower increases with wheel speed so what is it that gets you moving?? power output is expressed as the engine's torque multiplied by the rotational speed. so at lower rotational speed your basically working more on torque.. if your racing horsepower will come into play largely at high RPM/speed. ever wonder why you can dyno a truck in 4th gear and get one horsepower and torque number then dyno in overdrive and get higher horsepower numbers and less torque???
I'd love to see a V10 try to pull with a PSD with the gears the PSD came stock with.. 3.73's.. that could get pretty funny.
Old Jun 25, 2010 | 09:17 AM
  #5530
Johnny Langton
Define your interpretation of "superior".
JL
Old Jun 25, 2010 | 09:19 AM
  #5531
Jrfish007's Avatar
Jrfish007
The gas engine needs those gears to get into the RPM's where it can make power. If you compare the 2 engines with the same gears, there will be an advantage to one engine over the other.
Why not compare both engines with 4.88 then? the diesel will spend most of it's time shifting while the gasser will be pulling because of it's greater RPM range. To be fair, we should compare with what they came from the factory with.
Old Jun 25, 2010 | 09:23 AM
  #5532
Jrfish007's Avatar
Jrfish007
JL
reminds me of Clinton asking them define "sex"
I have to agree with Mountaineer on this one though. By superior I mean all around performance; everything from easy of pulling, mpg, etc.
Old Jun 25, 2010 | 09:27 AM
  #5533
phillips91's Avatar
phillips91
Originally Posted by Jrfish007
If that was antifreeze that got into the oil, every bearing in the truck would need replaced. Every rod bearing, the main bearings, turbo bearings, cam bearing... basically the entire engine would have to be stripped and rebuilt.
It's possible went he piston went bad, it let some antifreeze by and into the oil...
Even if that was the case I still can't see if being $18,000. I can rebuild a stock Ford small block gasser(never rebuilt a modular, so I can't quote their price) for less than $2,000. That includes a new cam, pistons, rings, all the bearings, machine work to have it balanced and bored and all new gaskets. If it costs $18,000 to completely rebuild a 6.4, that is more than it would cost me to buy a low mileage v10 with a complete truck around it lol.
thats why newer trucks have a warrenty
Not everyone trades in their truck when the warranty runs out. Some people don't even buy trucks new enough to have a warranty. If it is going to cost that much to rebuild a 6.4 then that means there will never be one in my driveway. Personally I think the dealer was just trying to rip him a new one though. Like the guy in the 5.4 section that was saying his dealer charged him over $600 to change his spark plugs.
Old Jun 25, 2010 | 09:39 AM
  #5534
Jrfish007's Avatar
Jrfish007
I admit $18k seems a little high. I would be curious to know how much a brand new turnkey 6.4 costs from Ford? But turbo's do add some complexity. I know a new turbo for example is around $3k for my Saab, not that I have had to replace it nor would I buy one brand new, but that is the cost of it. I think I could see a complete rebuild running about $5-6k for parts all brand new OEM from Ford. And generally parts and labor are equal, so $10-12k total sounds more reasonable to me for that.
You mean it doesn't cost $600 for new plugs? The Saab dealer told me they wanted $645 for new rear brakes (pads and rotors, NO calipers) on my car. On the way home I stopped at advanced auto and bought rear brakes and rotors for $140 and changed them the next day.
After the warranty is out, my cars and trucks don't see a dealer until I trade them in.
Old Jun 25, 2010 | 09:52 AM
  #5535
Johnny Langton
No,it's nothing like Clinton's word games.
Diesel owners typically have a broken mentality that their engine is superior simply because it allows them to pull a load in OD without downshifting. This simply means that the engine's configuration allows it to pull at that engine speed. A turbocharged gasoline engine will do the exact same thing.
Yes,the diesel will use less fuel-NOBODY is arguing that. But with the current cost of gasoline being $.20-$.40/gallon less than diesel, much of that fuel economy difference will be lost in fuel cost.
Compare the videos that we've already posted in this and other threads. Tom's 6.4L/3.73 truck and my 6.8L 3V/4.10 truck both accelerate from a dead stop up to the legal speed limit in comparable times. His truck can maintain that speed over hills better than my truck does simply because it has forced induction. A N/A diesel of the same displacement will not be able to do that-it'll behave the same as a N/A gasoline engine.
JL
