Sponsored by: Real Truck
Gas vs PSD
Old Jun 28, 2010 | 02:23 PM
  #5716
Lead Head's Avatar
Lead Head
Originally Posted by strokin'_tatsch
have fun controlling the VGT. much easier to run one from a 7.3 or even an HX35 from a cummins.
Actually a normal waste gate actuator is perfectly capable of controlling a VGT turbo. They even have aftermarket electronic VGT controllers now! You can pretty much make the turbo spool at idle with them.
Old Jun 28, 2010 | 02:41 PM
  #5717
Jrfish007's Avatar
Jrfish007
Originally Posted by Rush117
A 6.0 turbo will launch all 10 spark plugs into adjacent counties. Maybe little drag chutes will help you find them.
Old Jun 28, 2010 | 03:17 PM
  #5718
Jrfish007's Avatar
Jrfish007
Okay... diverging for just a minute...
Just out of curiosity, any know if there is a kit out there for supercharging the V10, the 3V V10 that is.
I've seen a few kits, but all for the 2V.
Old Jun 28, 2010 | 03:21 PM
  #5719
Johnny Langton's Avatar
Johnny Langton
I haven't seen any. IMO-leaving the OE intake manifold in place and adding a centrifugal SC or a custom turbo would be the best setup.
JL
Old Jun 28, 2010 | 03:49 PM
  #5720
strokin'_tatsch's Avatar
strokin'_tatsch
Agreed!!!
Old Jun 28, 2010 | 04:15 PM
  #5721
bill11012's Avatar
bill11012
Modular motor junkie
It could be made to deal with the boost just fine. I have seen a 4.6 made to run 30PSI.
Old Jun 28, 2010 | 06:30 PM
  #5722
strokin'_tatsch
And what had to be done for it to take the 30PSI all day long everyday??? and what would you have to do to make a V10 take that? my diesel is good for around 40 psi in stock form.. at that point i need headstuds, valve springs, and then i should be able to take it up a few more notches. i already have both of those so i'm ready to do some rat killin'.
Old Jun 28, 2010 | 06:46 PM
  #5723
bill11012's Avatar
bill11012
Anything and everything you can imagine. The 30PSI 4.6 I saw was a 1300HP mustang.
The V10 does not need anywere near the boost you 7.3 does to make big power.
How long can you run WOT before your EGT's get out of hand?
Old Jun 28, 2010 | 07:07 PM
  #5724
Lead Head's Avatar
Lead Head
30 PSI on a 3v V10 would be making well north of 1000HP, that is for sure.
Old Jun 28, 2010 | 07:39 PM
  #5725
phillips91's Avatar
phillips91
I run 18 psi on a 2.3 four cylinder with no issues. A v10 can handle 8 psi with no mods at all. Above 8 and you are looking at needing an intercooler. I highly doubt you would need more than 8 psi on it though.
Old Jun 28, 2010 | 07:45 PM
  #5726
Lead Head's Avatar
Lead Head
A mild turbo on a V10 would be interesting, just a few PSI boost. Not really enough that it would add tons of power, but you'd have the benefit of not loosing power at altitude. Or get a VGT turbo and move the torque peak down a thousand or so RPMs. Amazing what a turbo can do.
Old Jun 28, 2010 | 08:16 PM
  #5727
bill11012's Avatar
bill11012
5 Star is buiding a 2V turbo V10.
https://www.ford-trucks.com/forums/9...-tow-haul.html
Old Jun 28, 2010 | 08:44 PM
  #5728
Sand_Man's Avatar
Sand_Man
There's some good articles in this months issue of Hot Rod magazine about turbo stuff. If it's semi-affordable, I'd love to turbo mine. As stout as it is now, I'd love to see how it would be turbo'd! I mean look at the huge difference it makes with diesels!
Old Jun 29, 2010 | 06:58 AM
  #5729
Jrfish007's Avatar
Jrfish007
4.6's are nothing like our engines though. The only comparable engine is the 5.4 and seeing as ford was willing to back that one with a supercharger (i.e. put a warranty behind the truck), I would presume it can handle a few psi.
Old Jun 29, 2010 | 07:23 AM
  #5730
Johnny Langton
No sir,you're totally wrong.
The modular engine family are all built the same. Same materials, same process, many shared parts. The only components that are not the same between a 4.6L and a 5.4L/6.8L are the items that are affected by the longer stroke and deck height of the engine. They all use the same con rod bearings, main bearings, piston rings, camshafts, followers, valvepsrings, etc, etc, etc.
The only difference between the 5.4L in the Lightning and the N/A version are the pistons and the induction system. Some people will talk about the crankshaft being different, but some of the N/A 5.4L engines had the forged crank as well,so that's not really worth discussing.
6-8 psi of forced induction boost on a stone stock modular will last as long as you don't abuse it, and have it tuned properly. And with that small amount of boost on the 6.8L, it'll show impressive gains.
JL
