Sponsored by: Real Truck
Gas vs PSD
Old Jun 24, 2010 | 07:33 PM
  #5476
bill11012's Avatar
bill11012
Modular motor junkie
Why is that?
Mine still works fine, but I have yet to do it under a load. Planning on it when I do the loaded 0-60 vid with it.
Old Jun 24, 2010 | 07:40 PM
  #5477
Sand_Man's Avatar
Sand_Man
My definition of a power shift is with the throttle to the floor, and then stab the clutch, yank on the shifter and hope it all goes well, never liftting off the throttle the whole time. I doubt very seriously it could be done with ANY truck trans on the planet.
Old Jun 24, 2010 | 07:56 PM
  #5478
kx450frider617's Avatar
kx450frider617
Originally Posted by bill11012
I am game for that.
My 01 will out pull any stock truck ford made before late 03.
With its gearing it can out pull the averge stock 3.73 auto 6.0 too.
Is your v-10 totally stock?
  #5479
Tom's Avatar
Tom
I'm with Sand_Man here.
You are attempting to take an engine with a heavy flywheel at wide open throttle belting out over 400 ft-lbs of torque from 5,500 RPMs to 3,000 RPMs in a fraction of a second through a friction coupling.
Are you nuts?
Old Jun 24, 2010 | 08:01 PM
  #5480
kx450frider617
IMO, yea you can get a gas engine to run faster than the diesel but diesel engines are designed for towing. If you need to tow large trailers buy diesel, if its daily driver and light tower buy gas. There's a reason every commercial heavy duty machinery are all diesels. I also think a huge truck needs to sound like one. Its funny when your standing next to a huge lifted v-10 and it sounds like a little f-150.
Old Jun 24, 2010 | 08:02 PM
  #5481
phillips91's Avatar
phillips91
Originally Posted by Crazy001
I would go further than that and say I'd like to see a 6.0L/6.4L auto and manual run in a similar test as to what we did in Millersburg. I'm pretty confident the 5R110 would put a hurtin' on the ZF6 on a very steep grade for two reasons.
Turbocharged engines need time to build boost, and every time you shift you'd have to build boost all over again. The auto can shift with power being applied so there's no lost boost.
Secondly, the torque converter makes launching that much weight on a grade a stupidly simple affair. Mash the go pedal, release the stop pedal, and away we go. No burnt up clutches, no stalled engines, just seamless power.
Depending on the driver, the auto for the psd probably is the better way to go. It won't put down as much tractive force in 1st gear as the manual, but a steep 1st in a psd has you shifting at around 12 mph. That little bit of a start is probably offset by slow shifting, turbo lag, etc. I would like to see the v10 with a manual to show that with proper gearing it will be able to jerk the automatic psd out of the hole like nobodies business.
If you are ever down this way feel free to stop in and chat for a while. I think you would be pleasantly surprised by how mine pulls in 1st Oh, for what it's worth I checked our 0-35 mph times from our videos. The 6.0 went from 0-32 in 23 seconds, but then it shifted and took another 13 seconds to pull from 32 to 35 mph. Total time was 36 seconds 0-35 mph. The 7.3 took 28 seconds to go from 0-25 and never hit 35 mph. The v10 took 19 seconds from 0-25 and never hit 35 mph. Your 6.4 took 25 seconds to go from 0-35. My 5.4 took 33 seconds to go from 0-35. Not too shabby for a 2v 5.4, especially with me letting up to go over some road construction and around a turn and considering my hill was a 23% grade compared to your alls 15% grade.
Old Jun 24, 2010 | 08:03 PM
  #5482
CampSpringsJohn's Avatar
CampSpringsJohn
Powershifting under a load is a great way to rip teeth off gears, twist u-joints, and snap axle shafts. No different than popping the clutch.
Old Jun 24, 2010 | 08:11 PM
  #5483
Tom's Avatar
Tom
And the V10 isn't? If it wasn't designed for towing why is it only available in 3/4 ton and larger pickups?
Even an F-550 isn't huge, and sound has nothing to do with how an engine handles a load. Mine is much quieter than the 7.3L PSD and has MUCH more power. So is the V10!
Super Duty pickups aren't heavy duty...they are't even medium duty! Heavy duty engines do NOT have 8 cylinders.
Old Jun 24, 2010 | 08:18 PM
  #5484
kx450frider617
What im trying to say is diesels PERIOD are made to work. We have our own peter built flat top with a CAT 3406 that puts out 500 HP. I just think its funny when you can't hear the engine running, I wish the new engines weren't so quiet.
Old Jun 24, 2010 | 08:28 PM
  #5485
Sand_Man's Avatar
Sand_Man
Diesels are made to work? Hmmm, blanket statements like that are what causes arguements (all V10's suck, all diesels are breakage-prone, all Fords are great trucks, etc). Case in point: one of my wife's freinds has a diesel that couldn't pull a trailer on a bet! Of course it's in a Beetle, but still, you get the idea.
Old Jun 24, 2010 | 08:51 PM
  #5486
bill11012's Avatar
bill11012
Yes it is.
Are you nuts?
I was think more like over 2-3 seconds, rather than just dumping the clutch.
Nothing I drive has ever had a clutch problem related to that.
Well, you say it like that and it sounds like a bad idea.
Old Jun 24, 2010 | 08:56 PM
  #5487
Tom's Avatar
Tom
So you think a Volkswagen Golf TDI would make a great tow vehicle simply because it's a diesel? Or one of the high strung diesels used in some racing applications over in Europe? Come on now, that's just ridiculous.
Heavy duty gasoline engines "PERIOD" are also made to work. Ford doesn't make a long stroke modular engine(except GT500) that's not made to work. In fact, there are many satisfied owners that have used their 5.4L and 6.8L to tow trailers for over 200,000 miles without any problems.
Quietness has nothing to do with capability. As I stated above my 6.4L is far quieter than a 7.3L engine and produces far more power. The new 6.7L PSD is more powerful and quieter still. In my previous career I had two trucks with a 14L Detroit Series 60 engine, and two trucks with a Caterpillar C15. The Cats had more power and were much quieter. Noise output has no bearing on power output!
Old Jun 24, 2010 | 09:10 PM
  #5488
Rush117's Avatar
Rush117
I am game for that.
Rather than drag racing up a hill, which is pointless, how about several trucks hitch up to identical trailers in Boston and compare fuel expenditures when they arrive in Los Angeles?
Old Jun 24, 2010 | 09:35 PM
  #5489
kx450frider617
When did i say the noise output affect power output? I was saying when I see a truck I would like to here it's diesel engine running and SOUNDING powerful. I said it's funny when you see a big lifted truck and can't even hear it. It's my preference. I like the noise.
Old Jun 24, 2010 | 09:36 PM
  #5490
Tom's Avatar
Tom
I was think more like over 2-3 seconds, rather than just dumping the clutch. Nothing I drive has ever had a clutch problem related to that.
Okay, let's think of this another way.
Do you think your driveline would survive for very long if you were to shift like that frequently while towing?
Automatics are designed to shift under power, this is why we can do this all day long with as heavy a trailer as you please. The 4R100 isn't a good example of a modern automatic.
I don't think I'll be driving to Texas any time soon, but if I do you can take mine for a spin. Absolutely no comparison to the 4R100!
