Sponsored by: Real Truck
Gas vs PSD
Old Jun 23, 2010 | 09:40 PM
  #5416
mountaineer27's Avatar
mountaineer27
this has nothing to do with this forum but thought all would like it!
Old Jun 23, 2010 | 10:30 PM
  #5417
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Well yes, you are correct. But my question had nothing to do with your choice of engine. 50 years ago engines with 120 horspower were pulling the same weight you have and a lot more. They just had the axles, chasis and gearing to do it safely. Your photo looks like your rear axle is overloaded and you have no weight on your steering axle.
In any case, what does your overweight axle have to do with a V10 vs PSD thread?
Originally Posted by Kajtek1
You must be driving gaser
The truck pulled the weight just fine and I drove the I15 from Vegas to LA where there is a famous grade with lot of spots with burned asphalt on the shoulder.
The only problem the set has is weight distribution. While the truck has long rear overhang, the trailer has long front overhang. That puts most of the weight on the coupler. Now with air helper bags and excavator put couple feet towards the back of the trailer , I can fly
Old Jun 23, 2010 | 11:00 PM
  #5418
Kajtek1's Avatar
Kajtek1
Very simple.
V10 owners have NO IDEA what PSD are capable to do
Old Jun 23, 2010 | 11:10 PM
  #5419
Sand_Man's Avatar
Sand_Man
Maybe I don't, but then again, the new Dodge 6.7 I've driven is a hell of a lot more torquey than any 7.3 and it wasn't enough to keep me from buying a V10 anyway.
Old Jun 23, 2010 | 11:39 PM
  #5420
Kajtek1's Avatar
Kajtek1
Torque is not everything to get you to final destination.
We are comparing several PSD here, but fact is that the 7.3 liter that is on the market for 13 years still has no competition in reliability and longevity.
Old Jun 23, 2010 | 11:42 PM
  #5421
Kajtek1's Avatar
Kajtek1
Have 8V71 in my motorhome.
Suppose those engines have been on drawing boards during WW2 and still in some places are running strong.
Old Jun 24, 2010 | 01:15 AM
  #5422
Lead Head's Avatar
Lead Head
7.3 PSDs were only on the market between 1995 and 2003. 8 years.
Old Jun 24, 2010 | 06:37 AM
  #5423
Jrfish007's Avatar
Jrfish007
Originally Posted by CampSpringsJohn
So, the PSD makes for a better front end weight?!!!
Yes actually, the V10 is about 400-500 lbs lighter than the PSD. Remember the conversation about diesels requiring stronger parts, those stronger parts have more weight to hand the higher compressive forces of the diesel.
Old Jun 24, 2010 | 06:41 AM
  #5424
Jrfish007's Avatar
Jrfish007
Yes, so they have been out for almost 15 years. And since they were based on an already existing medium duty truck engine, their design is way over 20 years old. Comparing them to the most recent Cummins that was designed only a few years ago is kind of silly, of course the newer engine will be better.
I think by market he means new and used markets.
Old Jun 24, 2010 | 06:43 AM
  #5425
Jrfish007's Avatar
Jrfish007
Very simple.
Thanks, but I had PSD. I just have no need for one at the moment. As I already said, the $7k for a PSD looks far better in my 401k than sitting in my driveway depreciating away.
Old Jun 24, 2010 | 06:47 AM
  #5426
Jrfish007's Avatar
Jrfish007
While that is true, when you have lots of weight, torque is what you need to keep moving. Of course you have to combine that with gearing and many other things, including hp's.
Old Jun 24, 2010 | 06:48 AM
  #5427
Sand_Man's Avatar
Sand_Man
Well then what is your criteria for a great engine? Whatever it is, the 6.7 Cummins performs better. And if longevity is all you're worried about then why not get a flathead Ford? They've been around since 1932,so by your method it must be the best engine ever!
Old Jun 24, 2010 | 06:51 AM
  #5428
Rush117's Avatar
Rush117
Very simple.
I have no doubt that a V10 could pull that load.
Old Jun 24, 2010 | 07:05 AM
  #5429
Sand_Man's Avatar
Sand_Man
Originally Posted by Jrfish007
... Comparing them to the most recent Cummins that was designed only a few years ago is kind of silly, of course the newer engine will be better.
While that's true, my point was that while he may get all excited owning a diesel, they aren't the only thing out there. I've driven 6.0 and 6.4 Fords and 5.9 and 6.7 Cummins Dodges so I do know exactly what they are capable of, yet I still own a V10 Ford by choice, not because I'm some uninformed idiot.
Old Jun 24, 2010 | 07:06 AM
  #5430
Jrfish007's Avatar
Jrfish007
Here we go............
