Sponsored by: Real Truck
Gas vs PSD
Old Jun 22, 2010 | 07:30 PM
  #5326
mountaineer27's Avatar
mountaineer27
good call. i was mistaken. i thought international owned powerstroke. thats why ford went with the scorpion name
Old Jun 22, 2010 | 08:01 PM
  #5327
ChargersFanInCO's Avatar
ChargersFanInCO
I believe "Scorpion" was their developmental code-name like Froyo is the code-name for the 2.2 Android Operating system on the phones.
Old Jun 22, 2010 | 08:20 PM
  #5328
Tom's Avatar
Tom
3.73s could be had on an '08 SRW 6.4L truck, so the 3.73 rear end comments are still valid for the 6.4L trucks.
Old Jun 22, 2010 | 08:23 PM
  #5329
phillips91's Avatar
phillips91
Originally Posted by ChargersFanInCO
If you happen to have a personal problem with me, take it somewhere else. Or, you can PM me and I'll give you my address so we can discuss things in person at a time of your choosing. I'm done responding to your postings, so from this point forward, don't respond to mine, even in the third person like you like to do.
I don't need to PM you. My problem with you is that you think every post is an attack on you or your truck just because someone disagrees with you. Then you get all riled up because someone says something like "most psd's" came with whatever it was. Yeah, 4 years is a big chunk of time. But so is 9 years of the 99-07 models. Then throw in the fact that F series sales have gone down quite a bit every year since 07 it would seem to reason that there are more of the 99-07 models on the road than the last 4 years worth. Twice as many years, more sales per year="most" to me.
Old Jun 22, 2010 | 08:33 PM
  #5330
ChargersFanInCO
Yep, I see that...they seem to have stopped at job 3 in the 08's though...don't know why. I have the 3.55 and would be just fine with the 3.31 as far as I can tell.
Old Jun 22, 2010 | 09:27 PM
  #5331
bill11012's Avatar
bill11012
Modular motor junkie
What I read when they did it is that the 6.4 was not getting the mileage they thought it needed to, so they changed it along the way.
Tom, you truck is a job 2? I know it has the 3.73s.
Old Jun 22, 2010 | 10:37 PM
  #5332
Tom's Avatar
Tom
Mine's a Job 3, built in March of 2008 if I remember right. The 2009 trucks were changed to only offer 3.31 and 3.55 gears.
3.31 gears would put it at a 12% torque disadvantage in any particular gear compared to the 3.73s, and 3.55s would be at less than a 5% disadvantage. I can see either ratio towing lots of weight without any problems.
Although it's kind of neat being able to climb 3-4% grades on the highway at 19,500 lbs in overdrive, so I don't mind my 3.73s!
Old Jun 22, 2010 | 10:54 PM
  #5333
Kajtek1's Avatar
Kajtek1
Neat till you get to diesel pump and have to pay for that.
I am pretty annoyed with my PS screaming at 3000 rpm doing 75 mph
The only thing that sweetens the situation is the fact that even with 10 k empty weight and high differential ratio I still get better mpg than Bill
Old Jun 23, 2010 | 06:37 AM
  #5334
phillips91's Avatar
phillips91
What rear end does yours have? Turning those rpm's at that speed sounds like at least a 4.30 to me. Mine has a 4.10 and is turning ~2,700 at 75 mph.
Old Jun 23, 2010 | 07:25 AM
  #5335
Jrfish007's Avatar
Jrfish007
I think I hit 3k right around 80 mph... But I don't trust a tach that much, I would have to hit the button on the dash to check my true RPM.
Old Jun 23, 2010 | 07:29 AM
  #5336
Jrfish007's Avatar
Jrfish007
Hummm.... I pretty sure that is over your towing capacity for that truck, I don't have the charts for an '08 on hand. That is well into the DRW range. You probably don't care much, but if you where in an accident, your insurance company may care.
Old Jun 23, 2010 | 07:30 AM
  #5337
Jrfish007's Avatar
Jrfish007
Nope, that's what I thought to. But apparently Ford owns that name, and according to the chief engineer, they have quite a bit invested in that name.
Old Jun 23, 2010 | 07:42 AM
  #5338
Tom's Avatar
Tom
If that were the weight of just the trailer you'd be correct. It'd take an F450 to pull those kind of weights legally. Trailer weight including what was on the tongue was somewhere between 10,500-11,000 or so.
  #5339
phillips91's Avatar
phillips91
I may be mistaken, but I think Tom is talking about 19,500 gcw and not that he is towing a 19,500 lb trailer. Either way, the tow ratings from Ford are just a recommendation. The GVWR and RAWR are the two legal numbers to worry about.
Edit-Tom beat me to it lol.
Old Jun 23, 2010 | 08:02 AM
  #5340
Jrfish007's Avatar
Jrfish007
ahhh... I get it.
