Sponsored by: Real Truck
Gas vs PSD
Old Mar 31, 2010 | 10:00 PM
  #3976
clintusaf's Avatar
clintusaf
Originally Posted by Pinky Demon
But if you do get a new truck with the diesel, you won't be paying a mere $4000 anymore, sir.
uummm.....i think crazy001 just said that. echo....echo....echo
and besides like i said, i won't ever buy a new truck. whether it be a V10 or a diesel. they're both too much for me to swallow, especially when i know first hand that if you are patient, you'll run across a good deal on something used that someone else already took the hit on it. no offense crazy001.
Old Mar 31, 2010 | 10:26 PM
  #3977
krewat's Avatar
krewat
FTE Leadership Emeritus
Originally Posted by phillips91
The 8 mpg and shooting plug stories about the v10 and frequent wrecker trip stories of the 6.0 have kind of pushed me away from both.
If you maintain your vehicles the way you say you do, and take care of the plugs with anti-seize, you have nothing to worry about.
From late in model year 2002, up to 2004, the 2-valvers are very safe. And even then, you have nothing to worry about. I have a short-thread 2-valver, and I am not in the least worried.
You have about the same chance of running something over in the road and taking out the oil filter (or the pan itself) and running the oil out of the motor.
Old Mar 31, 2010 | 10:53 PM
  #3978
driximus's Avatar
driximus
Originally Posted by Sand_Man
28 mpg? 28mpg? Did you say 28mpg? I swear the internet has now offically become a liar's paradise....
Dave whitmer IRCC has a 7.3 built for mpg and last I heard he makes 26 or 27 mpg
Originally Posted by ciscofreak
Kind of ironic a V10 owner would say mods for a diesel are ridiculously expensiveYou do remember the V10 came with the 4R100 too right? I have driven quite a few of these and they were painfully slow towing the hills around here. Make sure you stop at the top of every hill to helicoil your plugs back in.
Didn't you hear? The brakes on the diesels are smaller and the turbos will implode if you drive your truck up hills without stopping at the top. I guess he
she go to the trucking forums and spread the word that everyone must stop at
the top of a hill and let the turbo cool.
That statement wins for "Most Ignorant" statement of the year on this board so far.
I would like to nominate quote in my sig for that.
Old Mar 31, 2010 | 11:09 PM
  #3979
bill11012's Avatar
bill11012
Modular motor junkie
You mean the one you edited down so it would make less sense?
Originally Posted by Lead Head
Torque is NOT work/power. Power/work is torque (or a force) applied through a distance.
No modern dyno measures torque either. All modern dynos measure power and then derive torque through calculations.
Old Apr 1, 2010 | 07:07 AM
  #3980
driximus's Avatar
driximus
No it was edited for purposes of fitting into my sig. And the edited out part has nothing to do with it being contradictary to its self. He is trying to describe the difference between HP and TQ however he mixes them up easily and gave me a great quote for my Sig.
Old Apr 1, 2010 | 07:28 AM
  #3981
phillips91's Avatar
phillips91
That's actually why my other truck is a 5.4 instead of a v10. I had a new v10 picked out and was ready to buy it, but came across my 5.4 at an estate sale. I got the truck and a car hauler for less than half of what the truck booked for.
Old Apr 1, 2010 | 07:53 AM
  #3982
Rush117's Avatar
Rush117
The "applied through a distance" part is significant. Work = Force Times Distance, which is what he was saying. You edited it to say Work = Force Times ...
Your editing says more about you than it does about Lead Head.
Old Apr 1, 2010 | 08:41 AM
  #3983
phillips91's Avatar
phillips91
Was there a change in the thread design in 2002? My 5.4 is a 2000 and I haven't had any trouble out of it. It only has 35k miles on it, but about 20k of those have came with between 8-15k lbs hooked to it. I didn't know about the plug problems when I bought it and have been hesitant to buy another once since I found out.
My worry isn't about how well I maintain my vehicle or my skill level. I just don't want to get one that wasn't put in right at the factory by the guy that knows nothing about working on an engine. Then I am stuck with the bill for a problem that happens at 20k miles and isn't covered by warranty. If the plugs are supposed to be changed at 80k miles and one blows out at 50k miles, then I think Ford should have to pay to fix it (as long as the plugs haven't been changed). If it was their plug put in by their employee then it should be their responsibility to fix it.
Old Apr 1, 2010 | 10:05 AM
  #3984
brian42's Avatar
brian42
Veteran: Navy
Dave whitmer IRCC has a 7.3 built for mpg and last I heard he makes 26 or 27 mpg.
I saw an article where somebody made their PSD for MPG. Tapered tonneau, 2WD, weight stripping and crazy tall gears (in the low 3's IIRC).
Power to them if that's what they want to do. Sure I'd love to get almost 30mpg, but I didn't buy my 4 ton, non-aerodynamic, 4WD to sip fuel. While I may not impress anybody with 13.5mpg overall, I sure have a good time doing it!
Old Apr 1, 2010 | 10:42 AM
  #3985
krewat's Avatar
krewat
For the record (again):
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
Old Apr 1, 2010 | 02:36 PM
  #3986
Lead Head's Avatar
Lead Head
You cut off the most important part of what I said, it went from being correct to just making no sense at all.
Old Apr 1, 2010 | 03:20 PM
  #3987
scraprat's Avatar
scraprat
Top Answer: 5
Isn't this thread now about that. This is it's own soup opera. I keep coming back to see who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, who's right, who's wrong, you get the idea.
Old Apr 1, 2010 | 03:48 PM
  #3988
krewat's Avatar
krewat
This thread is what is called "containment"
Oh, and a little bit of
Old Apr 1, 2010 | 04:11 PM
  #3989
scraprat's Avatar
scraprat
Top Answer: 5
It's a train wreck, I want to look away but just have to look.
Old Apr 1, 2010 | 06:40 PM
  #3990
clintusaf's Avatar
clintusaf
It is ridiculous, isnt it. The fact is, we all have some badass trucks. We just have different opinions on which one is a better work truck/daily driver.
I do think its awesome that this thread has almost 4,000 posts! Never seen one bigger.
