The HHO injection thread
2. The electrolyte does not get used up. Some of it may pass to the first bubbler. It can be put back into the main cell so you should never have to add any.
3. The amperage in the cell goes up as the temperature rises. Some have recommended a PWM speed controller ~30 bucks on the internet (Bakatronics - Model Railroad Electronics).
As far as your sensing the water level, a passive system should be used . I would never put an electric current in the reaction chamber. Call me paranoid. I like big noises, but I like them somewhat controlled. A simple sight tube to see the water level should be all that you need. I understand that you can run for at least a week before adding water. The recirculating water system is way overkill. Just put a bubbler at the reactor and another at the engine. Using the minimum size line is an excellent ides. One unit is operated at 65 PSI, so I guess a little back pressure is OK.
Recirculating serves many purposes for me:
1. Cooling, though I understand that a properly balanced system should not have a problem.
2. Installing the reactor remotely. This would allow me to install it under the truck and pretty much leave it there.
3. Easily maintain water level under the hood. This goes with #2.
4. Increasing volume of fluid should make the small amount lost to the reation have even less of an effect on the whole system.
5. Never have to worry about the plates in the reactor running dry.
It really depends on what I can find for a constant use pump. Something small, low power draw and long living.
That speed controller looks interesting.
I was going to talk to an engineer friend of mine that builds computers control systems for various applications, currently oil well control and monitoring systems. This is the kind of thing he would love to check out. If we could give him a list of requirements he could probably build an automated control system that could monitor and adjust the system on the fly.
What would we need to monitor?
Amperage - trying to maintain a constant
Water Temp - keeping it below boiling
If we could read the output of gas somehow that would be good too.
Engine load/speed
Glow plug activity
What else?
We would either want amps to be dependant on gas output and engine load or just to remain at a constant. I think it would be best to make the amperage held a variable, perhaps adjusted by a dial.
Now I just got my truck and I haven't turned a wrench in way too long so I would need lots of assistance but I could use my truck as a tool for him to get the info he needs. I have a 2005 6L PSD and I would assume that this information could be gathered a similar way from some of the other vehicles like the 7.3, right?
So, any information that you can share at this point would be extremely helpful.
Thanks!
Barry
uld be 1.957 Vdc and the target should be between 1.8 & 2.0. Now don't ask me how he came up with this because it is way above my head! If the other smarter guys here are not sure either, then I will get him to explain. But according to this redesign, we should be good to go. He is taking these drawings off to a machine shop buddy of his to get a quote on cutting it up....hopefully a waterjet.
So what do you think? and if anybody wants something similar, just send me your dimensions and I'll draw it up for you. Todd
Would you be willing to share the origional CAD files? This looks like a great place to start for me.
My only concern would be using only bolts down the center of the cell. Any bumping could cause the plates to flex and short. Not sure it is a huge deal but I think I would rather have two sets of bolts running through the plates to keep the spacing constant.
Absolutely......just pm me your email addy and I'll send it over in ADT2007 format. And that goes for anybody reading this.........
As far as movement within the cell, my tolerance's are pretty tight. I'm more worried about the assembly sliding into the pipe once put together. I've even thought I may need to grind the nylon nuts down a little for it to slide in......one day hopefully we will see! And plate flex I plan to look into that once they are cut. If they are fairly flexible then I planned to add another nylon bolt in the center. I would think that would be plenty in the short distance I have.
Dave, I built my unit exactly like a smack unit except I used 18" of PVC instead of 12". I plan on making a 1200 mile trip soon and wanted the extra volume.
Right now I have 8 teaspoons of baking soda to a gallon of water in the unit. When I first turned it on I was drawing about 10 amps and producing 1L per 3 1/2 minutes. It has been running 40 minutes with no increase in amperage. I am going to let her run as long as I can.
What amp meter are you guys using? The only thing I could find at the parts store was a -60 to +60 with marks every 30 amps. I want something more accurate than that.
Ok Be Safe
I'm going to use one out of a large battery charger. A friend burned his down. I don't think accuracy is that critical as long as the unit doesn't get too hot.
I see some kind of optional input that would be selectable to sense an open or closed circuit. This could be used for your own glow plug relay or some other control. All the controls would be connected to external relays to do the dirty work.
Is there anything else I'm missing?
He probably has something but does anyone suggest something to use for temperature measurement? I assume we want something non-metallic. Perhaps plastic coated?
Would we want this to have a display or is this a behind-the-dash, set it and leave it type of device? The problem with including a display is it would drive up the cost. Speaking of cost, what is the limit people would be willing to spend on components? I think he would like to make this a marketable product but of course he would need satisfied customers, at cost.
The breaking point of cost is important to help him pick components.
I appreciate any input!
Thanks,
Barry
I've been following this tread and I have got a 10,000 dollar question for any or all. Has any one tried to see what volume of gas is actually needed to make a combustion difference? I would like to get a general number of liters needed and then build up from there. I am sure the more the better ( because in theory a most combustion engines sould run off straight Hydrogen let alone H + O ), but what is the magic number that it starts to make a difference? How would one go about finding that number?
I'm still really worried about the small space at the ends of the plates, especially the longest center plates. I suppose an intermittent short at that point will have minimal effect on the whole system but any short will change the Amperage draw on the system.
I'm thinking that expanding to a 4" system and having 2 sets of bolts. I'm too lazy to draw it in chicken scratch so something like this:
|----x---------------------x-------|
Where x is the nylon bolt running through the plates.
