@cleatus12r I was considering the idea of using alternative sensors for MAP and EBP that would allow more accurate OBDII readings of the pressures encountered with higher powered 7.3s. Is rescaling those inputs in tuning a practical route to take, or would it be more trouble than it's worth?
Whoa now. You’re starting to get into Fast N Furious territory there. Next you’ll want wideband O2 sensors and accelerometers.
Cody, please tell me you’ll code an error message that reads “Danger To Manifold” in there somewhere.
@FordTruckNoob Actually it's primarily motivated by being cheap; the isspro boost gauge is 170 dollars, don't really want to add an EBP gauge, excessive gauge pods are costly and aren't "stealth" enough for my liking... if I could have accurate boost and EBP readings from the PCM that would save me money. Only two physical gauges I'd "need" would be pyro and fuel pressure, with the rest on the tablet.
I don't think they'd offer much advantage over the stock sensors in terms of tuning capability.
Sorry if I'm being unclear; I already use a tablet and forscan/torque to display that information, the problem comes with it not being reliable outside the sensor limits. I want to see whether it's workable to use sensors with bigger range and rescale in tuning vs having physical gauges for those parameters.
I cannot see why 0.009” would make any difference on engine to transmission adapter. It is not a rigid member and would easily conform to the block/transmission. If your flexplate was not compromised, I don’t think you’re fixing anything?
on edit: the torque converter moves close to 1/2”? when engine is bolted to transmission. Plenty of room to deck the adapter flat if desired.
There was a short time when some tuners were using the 6.0 MAP sensor and scaling tuning to make it work. My understanding is this added detail (higher MAP pressure) does not change fueling, etc and was therefore dropped as an option.
My guess is the AA (or Cody) could make this work for you, but i don’t think it will be more economical than a gauge and not sure how much more you can read... (I support your goal of ‘less stuff’/stealth)
Gotcha. I agree with SSJ that it will probably not be more economical but it would be great for data logging when one is beyond factory boost levels.
The machinist assumed they wouldn't be able to be re-used after taking the vice grips to em for removal prior to machining.
New ones are still available from Ford. They are HARD.
Little trick for next time:
Drill 1/4" holes in the block behind the dowels and use a drift and a hammer to get them out. No structural damage in doing this and you don't f-up the vice grip jaws.
Honeywell lists 5v pressure sensors for between 40 and 70 dollars. That's a lot cheaper than two gauges and their accompanying pods(?). Big thing I need to know is what absolute ranges would be best for EBP and MAP.
He's a machinist....he can make new ones. For that matter, have him/her measure them...I'll make them.
Think he was simply trying to save me money as, if they are a standard size, it'll be a lot cheaper to buy those than have him make some.
Appreciate the tip. Have passed it along to the machinist.
Got the rod bolts from International today and delivered them and the girdle plate/main studs to the auto machinist. Hopefully should know what size pistons to get tomorrow.
Boost is not a critical watch item. So if you’re not picky you could pick up a cheap mechanical gauge for $50 or so. I don’t want mismatched gauges myself, but just wanted to share the option.
I have a concern about using a MAP sensor outside of factory range. The PCM uses this in its table for fueling from what I’ve read. Please don’t take my word for it, but do get an expert like Cody to chime in before committing to the plan. I image you could get someone to write a modified table for your sensor but that could limit your tuner options.
Not critical no but it's something I want to monitor. Basically I can fit two gauges on the steering column which is a place I consider unobtrusive and easy to read at a glance. Fuel pressure and EGT would take those spots, and I'm not keen on having gauges elsewhere in more obvious locations. Ideally, everything else needs to be on a OBDII on a tablet that I can remove from the truck.
I definitely wouldn't install different sensors without those inputs being remapped in tuning, that sounds like a recipe for disaster. I've send an email to AA about the idea. Am waiting to hear back.
From a tuning standpoint, it's something that can be done but is a waste of time just to look at numbers on a gauge.
Matt at Gearhead was pushing the 6.0 sensor stuff years ago, not me. If there's a reason to limit fuel above 12 PSI (maybe sled pulling or drag racing with a ridiculous turbo or stupid-huge injectors), then it might be something to look at from a functional standpoint......not to see certain boost or drive pressure.
The problem with going to a wider-range sensor and in this case a sensor that reads 3 bars above 0 MAP instead of having a 3-bar sensor that wastes a third of its range to read vacuum (on a diesel, no less), is that resolution suffers when dealing with a PCM that doesn't have all that many data points. Not to mention that the person doing the tuning will have to have a sensor, a 5-volt power supply, and a bunch of time to actually map the sensor's voltage rise vs. pressure.
The formula specified by the datasheet wouldn't be sufficient for this?
