400 HP Engine Build - Input Needed
Old Apr 20, 2022 | 07:18 PM
  #286
PriusLover's Avatar
PriusLover
Continuing with this line of thought, perhaps you should stone the thermostat interface flat @PriusLover . Have you got a billet thermostat housing?
Yeah rando one from Amazon. I never had any issues with it leaking.
Finally heard back from the auto machine shop. 0.020 overbore pistons, standard size rod and crank bearings. Thankfully they're all still in stock!
Old Apr 29, 2022 | 01:22 AM
  #287
PriusLover's Avatar
PriusLover
Got the pistons today. Going to take them, turbo housing, and manifolds to get ceramic coated tomorrow. Removed the second piston rings to send to total seal for gapless conversion. Note: don't get the cheap piston ring pliers from the auto parts store; they are junk and will only serve to scratch up your shiny new pistons (insert all manner of angry swearing here).
Will also be sending out injectors tomorrow to Rosewood for a rebuild/single shot conversion, and my HPOPs to Terminator.
Have also been thinking about incorporating a Racor 4500 as I really hate all the oil build up in the intake. When combined with the total seal rings should result in a huge reduction of soot in the engine oil, meaning longer oil change intervals!
Old Apr 29, 2022 | 06:49 AM
  #288
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
I really like where this is going
Old Apr 29, 2022 | 03:44 PM
  #289
PriusLover's Avatar
PriusLover
I know it's cosmetic but gah it bugs me so. Nothing worse than a tool that makes things even worse vs if you didn't have it in the first place.
Went over the scratches with 1500 grits to remove any material proud of the surface.
​​​​​​​If you need to remove the rings spend the money on a good pair of ring pliers!!
Old May 3, 2022 | 05:26 AM
  #290
FordTruckNoob's Avatar
FordTruckNoob
I forget. Are you getting your pistons coated?
Old May 3, 2022 | 05:51 PM
  #291
PriusLover's Avatar
PriusLover
Yeah. Same place that does RRs coated pistons. High temp on top, slick coated skirts, oil shedding bottom. Also getting the manifolds and turbo housing done up in their satin black (said it's the most durable color).
Old May 7, 2022 | 04:34 PM
  #292
ESwift's Avatar
ESwift
CNCFAB
Still looking for ARP 250-6303 ? I found some
Old May 7, 2022 | 04:47 PM
  #293
FordTruckNoob
Showoff…..
Old May 7, 2022 | 05:46 PM
  #294
PriusLover's Avatar
PriusLover
@ESwift how much are they asking?
Old May 7, 2022 | 06:20 PM
  #295
ESwift's Avatar
ESwift
CNCFAB
I already bought them knowing someone would want them. I will pm you later. Visiting with parents
Old May 7, 2022 | 06:23 PM
  #296
FordTruckNoob
Dinner with his parents is very important as I understand it.
Old May 7, 2022 | 06:29 PM
  #297
ESwift's Avatar
ESwift
CNCFAB
It takes full concentration to act like an adult so they are proud of me
Old May 9, 2022 | 03:54 PM
  #298
PriusLover's Avatar
PriusLover
Terminator turned my pump around in a few days and got it back to me via USPS. Very impressed. I think I'm going to change out the rear snap ring though for one of those "internal teeth" rings like my PS pump has as extra insurance against rear blowouts. Anyone know what size snap ring the rear of the HPOP uses?
Jim at Rosewood gave me a call today saying injectors are done (I have a nasty cold... amazed he understood anything I said haha). Nothing out of the ordinary to report in regards to their condition. Great experience with Jim as we've spoken a lot about injector choices and related matters, and he always found time to relay the insights of his considerable knowledge in detail.
Also got some OSG spiral taps to clean up the block's main, head, and exhaust bolt threads (much better investment than ARP's over priced thread chasers).
Old May 9, 2022 | 04:02 PM
  #299
FordTruckNoob
If you are going to replace that circlip, have you considered a Spirolox retaining ring that provides full 360° retention?
https://www.smalley.com/retaining-rings/spirolox
Old May 9, 2022 | 05:01 PM
  #300
PriusLover's Avatar
PriusLover
Ive thought about those. The only thing that concerns me is I've had some ratchets that use those to retain the anvil, and the avils always wobble/are held in less tight with spiral retainers vs a snapring.
I guess I could compare the thickness of the spiral retainer with the snap ring and see how close it is.
