400 HP Engine Build - Input Needed
Old Mar 25, 2022 | 03:16 PM
  #151
FinnishStroker's Avatar
FinnishStroker
Originally Posted by KubotaOrange76
I figured it was cause he torques everything to yield
That’s what happens when you use Dugga Duggas instead of Ugga Duggas.
Wife always complains about coffee thermos too tight..
Old Mar 25, 2022 | 03:25 PM
  #152
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Have you contacted ARP to inquire when or if they will continue to produce 250-6303?
Some distributors indicate that an order will ship as soon as April 5 (eg M&D Distributors).
It would be a shame to have taken the motor down this far, only to reinstall stretched rod bolts.
Old Mar 25, 2022 | 03:38 PM
  #153
PriusLover's Avatar
PriusLover
They're thinking July or August, maybe.
To be clear, the International manual does seem to indicate you can re-use them.
Old Mar 25, 2022 | 03:42 PM
  #154
kd5zll's Avatar
kd5zll
Not to ask a stupid question... but have you called your closest/prefered international dealer and checked inventory and prices from them?
Old Mar 25, 2022 | 05:22 PM
  #155
PriusLover's Avatar
PriusLover
International can order them but they want 26 per bolt which is just insane. Some dealers around the US have the Ford bolt for 16 or so but usually only one or two on hand.
Old Mar 25, 2022 | 05:36 PM
  #156
FordTruckNoob's Avatar
FordTruckNoob
Well hell if you’re going to pay that much for the bolts you might as well buy billet rods that come with new bolts.
*ducks and runs*
Old Mar 25, 2022 | 05:43 PM
  #157
PriusLover's Avatar
PriusLover
Even if I wanted to they all seem to be out of stock anyway : /
I suppose if I really wanted to be cheap I could order a couple bolts from International and see if my bolts are indeed stretched.
Old Mar 25, 2022 | 05:53 PM
  #158
FordTruckNoob
These guys may have them in stock.
https://www.jegs.com/i/Manley/660/14...oaAo3OEALw_wcB
Old Mar 25, 2022 | 06:05 PM
  #159
PriusLover's Avatar
PriusLover
Based on what I'm seeing elsewhere I doubt it. There's one place that might have the Crower rods but I can't justify two grand on rods for a mild HP application.
One International tech I spoke with said that, per their manual, there's no indication that they are "torque to yield" or need replacement assuming they are in good condition. I have a line out to another tech who'll get back to me next week.
Old Mar 25, 2022 | 06:31 PM
  #160
FordTruckNoob
Justify it for a high-HP build then. 😁
Old Mar 25, 2022 | 10:16 PM
  #161
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Inventory Status: ARP estimates this item will ship to my distributer on 03-01-2022. Item should be available to ship on 03-10-2022.(ETA Missed) Mfr. Drop shipment: On average, this product will take 2 business days for Mfr. to ship.
Old Mar 26, 2022 | 03:44 AM
  #162
FinnishStroker
I don't think that bolt stretching can be measured.
Unless they have been stretched to braking point.
Maybe try to source bolts by specs only?
This is apples to oranges comparison:
ALWAYS when forestry machine track extension splits off,it's becouse of assembly with the old tired bolt.
Old Mar 26, 2022 | 07:40 AM
  #163
Dan V's Avatar
Dan V
If you're referring to measuring a bolt that is been removed and being measured, I think you may be correct. I do know that ARPmakes a device that you would indeed measure rod bolt stretch when torqueing them down.
Rod Bolt Stretch gage
Old Mar 26, 2022 | 08:05 AM
  #164
FordTruckNoob
I think you meant yield point.
I like the idea behind finding a bolt by spec. The trouble is trying to find the exact spec of the rod bolt.
Old Mar 26, 2022 | 09:57 AM
  #165
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Not rod bolts, but an example of necking that is handy for illustration.
Almost every red-blooded vehicle owner has experienced a little bit of necking.
And when things become too strained... it might be time to replace what was necked.
