400 HP Engine Build - Input Needed
Old May 9, 2022 | 05:19 PM
  #301
FordTruckNoob's Avatar
FordTruckNoob
I think any sort of retaining ring/clip/doodad that does not fit snugly in the groove will perform poorly. I wonder if it is feasible to put threads on that end of the HPOP to use a threaded collar instead.
Old May 9, 2022 | 06:59 PM
  #302
Bonanza35's Avatar
Bonanza35
Originally Posted by PriusLover
Ive thought about those. The only thing that concerns me is I've had some ratchets that use those to retain the anvil, and the avils always wobble/are held in less tight with spiral retainers vs a snapring.
I guess I could compare the thickness of the spiral retainer with the snap ring and see how close it is.
Did yours blow out? They are all made that way and usually work fine. If you change it, Joey won't guarantee it. I'd leave it. I've had mine for years now and I think I might be able to see a small drop to. I have one of his first HPOP's, it has work great!
Old May 11, 2022 | 01:32 AM
  #303
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
With Chet on this. Freshly rebuilt by a pro, don't mess with it.
My level of crazy here would be hit it with some Flex Seal.
Old May 11, 2022 | 07:17 AM
  #304
SkySkiJason's Avatar
SkySkiJason
The failures I’ve seen (RARE) blow the groove out of the pump body. I don’t see how a different ring would prevent that?
Old May 11, 2022 | 11:56 AM
  #305
PriusLover's Avatar
PriusLover
Fine fine I'll leave it alone : P
Returned the rod bolts to International yesterday. They hit me with a 20% restocking fee, but even after the ARP bolts, courtesy of @ESwift , still come out 50 dollars ahead.
​​​​​​​Auto machine shop says they are still on track for end of May completion.
Old May 12, 2022 | 01:59 AM
  #306
aawlberninf350
It's a Van Gogh
Smudging sage to bless everyone's efforts toward longevity of your engine.
Or maybe sacrifice a chicken too, not decided yet.
Old May 12, 2022 | 10:37 AM
  #307
Eaglescout94's Avatar
Eaglescout94
I’m hoping a speedy restock from ARP. My block is done, I have I believe everything ordered or sitting at the house already and I’m only waiting on rod studs and main studs. With my luck they’ll ship after I have surgery so everything will have to sit and wait a month or more.
Glad you’re getting everything lined up and together. If you feel like I do about mine you sure miss your truck.
Old May 12, 2022 | 06:47 PM
  #308
PriusLover's Avatar
PriusLover
If you have a pile of money just laying around you can get the rod bolts from International and the main bolts+girdle from CNC. Last I heard from ARP they were projecting August... dunno if that's slipped since.
Yeah it'd be nice to have two working vehicles again, especially since the Hyundai's engine seems to be destroying itself.
Old May 12, 2022 | 10:47 PM
  #309
ESwift's Avatar
ESwift
CNCFAB
I may have a lead on another set of the arp 250-6303 via a facebook club
Old May 12, 2022 | 11:57 PM
  #310
Eaglescout94
Definitely holler if something comes up. I was debating going with the CNC girdle and getting the studs with it. When I talked to BitterRoot, they were told from ARP June/July so hopefully early. I need the truck together for a camping trip the first of august. Obviously earlier would be better but I don’t want to rush the process. This time I will make certain everything is done exactly how I want it and I won’t have to redo anything, atleast not to laziness.
Old May 13, 2022 | 05:53 AM
  #311
RacinJasonWV's Avatar
RacinJasonWV
I wouldn’t expect anything early with the current supply chain issues. You’re more likely to end up with additional unexpected delays. I work in manufacturing and this has been life over the last couple of years.
Old May 15, 2022 | 10:47 PM
  #312
PriusLover's Avatar
PriusLover
As if I wasn't doing enough non-stock stuff on this engine, I've a line on a Horton electromagnetic fan clutch.
It comes with a normally open 210-198 degree switch... not sure if that'll pair well with my stock thermostat or if it'd be better to get the NO 205-193 switch?
Old May 16, 2022 | 06:49 AM
  #313
SkySkiJason
I don’t know which switch is best, but an on-demand fan should definitely increase POWER and MPG.
I have one from a bus engine I bought awhile back. Maybe I’ll make time to install it when I get around to swapping my engine out..... At the current rate, you’ll be done by then and providing feedback on all of your mods!
Old May 18, 2022 | 02:45 AM
  #314
PriusLover's Avatar
PriusLover
I do like power and MPG. If I could realize the 400+ HP goal while getting better MPG than before I'd consider this build a success. Also hoping some of these choices, like the total seal 2nd rings and maybe a racor ccv filter, will translate to longer oil change intervals too.
For the fan clutch this guide is the most complete one I can find. Will probably be adhering to most of it: https://www.powerstroke.org/threads/...n-drive.105255
​​​​​​​Picked up exhaust manifolds, turbo housing, and pistons from the ceramic shop. They did an absolutely beautiful job. No more rust concerns, and hopefully some tangible efficiency gains.
Old May 18, 2022 | 06:48 AM
  #315
ESwift's Avatar
ESwift
CNCFAB
Just be aware that injector more fuel, does not usually lead to more mpg. In order for that you would have to refrain from using that 400hp. That said, your setup seems like it should be very efficient overall
