I agree with your statement for the most part. I think the culture plays a part too though. To make gross generalizations, notice how the Japanese have a culture of quality and perfection? For example: fruits come individually wrapped, trains leave and arrive on time to the second, etc etc. The Chinese culture is one of gaining as much wealth as quickly as possible and that leads to some questionable behavior.
IMO, China is capable of producing quality merchandise and I have a grill accessories kit that is definitely of good quality. My understanding is that quality Chinese would cost as much as quality American so it's not imported. I used to yak a lot with an Egyptian immigrant when I was working and he assured me that we got higher quality Chinese stuff here than they do in Egypt. I knew the guy pretty well and had no reason to doubt what he was telling me. For some reason, I get a warmer feeling buying things like machined products made in USA. My research on the water pump bearings revealed that nobody makes them in the USA, at least not that I could find.
notice how the Japanese have a culture of quality and perfection? For example: fruits come individually wrapped, trains leave and arrive on time to the second, etc etc..
Leadership from supervisorial hierarchy, leadership from surrounding peers, leadership from historical culture and precedent, and leadership from the self-guiding compass within... all combine to produce a sum output of character... and that character determines quality.
Yeah I think the main bearings that are scored would look better if the metal hadn't been in the oil, but I'm glad they took the damage instead of the journal. Do you know if new pickup tube gaskets are Viton? In regards to the front cover, would a resurfacing of the LPOP making surface suffice?
You can have someone TIG weld the surface and then reface it. This is what we have to do when we rebuild 6.4's as new front covers are not always available.
No real need for Viton. Stock o-ring lasted 20+ years. Another mod you can do with the pan off is right where the pickup screen is, you can cut off the sheet metal covering the other half of the opening.
Dropped heads, crank, cam, rods off at the machinist today, will drop the block off Monday. Said they can tig the gear to the cam. Asked about the front cover resurfacing, said it'd probably be a lot cheaper to get a good core to replace it with (which they might be able to facilitate).
When I was a kid, Japanese stuff was the junk that Chinese stuff is today. Their stereos of the '70s were the first quality items I remember coming out of there and their cars weren't too far behind.
Not bad for having had two atomic bombs dropped on them.
Originally Posted by PriusLover
@FordTruckNoob looks like that link is for the gas engine camshafts?
Well crap. It is indeed. Sorry about that. I’ll look again tomorrow morning.
I can see what the cover on one of my parts engines looks like, shouldnt take too long to take off. Shipping may make the new one worth the extra cost though…
Been thinking about your front cover. My guess is that any capable machinist that has access to a Bridgeport, (VMC being better) could machine that flat in 30 minutes or less. (that includes set-up and the machining) If Deiselsite can *add* a bronze spacer, I don't see why removing say .020 from the LPOP surface is going harm anything.
