400 HP Engine Build - Input Needed
Old Mar 24, 2022 | 07:40 AM
  #136
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by Y2KW57
That's awesome! May I use this image in future posts please?
Originally Posted by PriusLover
Just call me...
As for injectors, bigger is always better.
Old Mar 24, 2022 | 02:04 PM
  #137
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
You have my seal of approval.
Old Mar 25, 2022 | 01:14 AM
  #138
PriusLover's Avatar
PriusLover
Reading over the International manual, it looks like they specify 95ft-lb for the bearing cap bolts (oil coated if re-using). Thing is a class 10.9 fastener for that size is notated in the manual as 79ft-lb (+/- 10%). Has me wondering if the bearing cap bolts and connecting rod bolts are reusable? If they are tightened that much have they permanently stretched?
Old Mar 25, 2022 | 05:32 AM
  #139
FinnishStroker's Avatar
FinnishStroker
I wouldn't reuse any engine internal bolts.
Old Mar 25, 2022 | 07:57 AM
  #140
FordTruckNoob
I’m with FinnishStroker on this one. Especially the fasteners on the bits that spin or reciprocate.
Old Mar 25, 2022 | 08:04 AM
  #141
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
I figured it was cause he torques everything to yield
Old Mar 25, 2022 | 08:44 AM
  #142
FordTruckNoob
That’s what happens when you use Dugga Duggas instead of Ugga Duggas.
Old Mar 25, 2022 | 09:33 AM
  #143
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Replace everything with ARP and build for 1000 HP.
Old Mar 25, 2022 | 10:45 AM
  #144
Dan V's Avatar
Dan V
When Swamp's did your build...they did this?
Old Mar 25, 2022 | 11:30 AM
  #145
FordTruckNoob
They sure did. All fasteners were replaced.
Old Mar 25, 2022 | 12:07 PM
  #146
PriusLover's Avatar
PriusLover
To think what might have happened if they had re-used the timing cover mounting bolts
Old Mar 25, 2022 | 12:25 PM
  #147
Dan V's Avatar
Dan V
So that's how they get 15k..
Old Mar 25, 2022 | 12:32 PM
  #148
FordTruckNoob
I know, right? They might have had to mill the front cover down by .002.
Don't remind me.
Old Mar 25, 2022 | 01:30 PM
  #149
PriusLover's Avatar
PriusLover
Too soon, too soon.
Old Mar 25, 2022 | 03:14 PM
  #150
PriusLover's Avatar
PriusLover
Rod bolt kit is on indefinite backorder, and the stock bolts are discontinued so I might have to re-use the rod bolts. @Bitterroot Diesel Don't suppose you have any floating around your shop?
