- cracked block, repair
- 1988 E-350 Cabriolet
- 429 build for towing
- 385 in a 74 Crew 4X4
- input ideas for a 460
- 429LIMA-4V sputter on start
- exhaust manifold getting too hot ?
- What kind and type of oil?
- what gear ratio &cam drive
- 1986 370 transmission options
- 429 piston rods
- Vacuum source on an Edelbrock carb...
- Going rate for a 460
- Quick Valvetrain Question
- 86 Duraspark Distributor Advance Setup?
- Starter: Works, Sometimes
- 429 thermostat and carb questions
- cold hearted 460
- How much $ to get these heads ready to bolt on?
- I want 500 hp out of my 460
- Pre-Mature cam failure article from Comp Cams
- hello all !!!
- 69 Lincoln Mk 3 429 or 460?
- Motor misses when Lights/Flashers on..
- Roller rockers and Cobra Jet Valve covers
- 460 stock intakes
- 95 460 crankshaft pulley
- 460 internal or external balance?
- timing
- 460 rebuild questions
