- Leak or moisture?
- 1979 4x4 farm truck
- mounting brackets for the small / contour rear bumper for a 79 F350
- Stereo mounting kit
- need help. Shifting/ starting issue and where to find gauges/ tail light harness
- Door jamb switch pigtail?
- Are 96 and 73 302's the same
- Clutch trouble?
- Ca Emissions 76 390: Getting Closer/EGR Question
- 1979 F150 Build Planning Help
- Oil pressure gauge/dummy light wiring
- Pictures with bed removed 79 F-150 style side 8' bed
- '76 heater core replacement
- Identifying side mirrors please
- Remove lower steering shaft?
- A little help with my engine swap
- best ways to remove surface rust?
- Short bed sides
- '79 ignition switch
- fender and hood alignment
- The cost of being cheap: / Avoid imports
- 79 holley 2bbl carb 465 cfm classic with hot air choke and vacuum secondaries.
- Break Lights Not Working
- Block difference?
- 1979 F150 with 351C Vacuum Questions
- C6 Transmission Slippage
- Master cylinder brake line help
- Front brake line clamp
- Dash light Issues
- replacing radiator support bushings
