Identifying side mirrors please
Old Mar 26, 2018 | 06:10 PM
ty.Harris's Avatar
ty.Harris
I'm looking for help in identifying what mirrors I have and what trucks/vans in any make or model have this style of mirror that swivels and has the 90* L bracket that goes in through the side. I'm looking for replacement glass and can't find it. Turns out the driver side is not OEM as close as it looks to the passenger housing, it is actually slightly smaller. The passenger one measures about 10.125 by about 7.125 if I remember. I'm looking to just get an entirely new housing off of eBay or local junk yard and paint it so I know exactly what it is off of when I need new glass again. Truck is a 1978 F150 5.8L 351M. Thanks everybody.
Old Mar 26, 2018 | 06:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Looks close to a type 8...about any glass/ mirror/windshield shop should be able to cut you a new piece of glass. If you can get the mirror off (ck for 1 bolt on the bottom of the mount tube) and take it to them.
Old Mar 28, 2018 | 07:47 AM
ty.Harris's Avatar
ty.Harris
Hey thanks, I've seen those pictures before with all the different styles. I guess I'll just grab a camper style mirror off an e150 or any truck older than a 90's at pullapart. I'd rather not have to get one made
Old Mar 30, 2018 | 01:18 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's not a Type 8, it's a 'gypo' aftermarket auto parts store mirror. Type 8's were stainless, this puppy isn't.
Lower pic shows the Type 8, compare it with the OP's mirror.
Old Mar 30, 2018 | 10:58 AM
meangreen92's Avatar
meangreen92
I took an old mirror from a projector TV, went to Menards and bought a glass cutter, and cut some new glasss for my Type 7 mirrors. One fell out so I need to cut out another. The mirror head needs to be crimped around the mirror glass to hold it on. I used pliers with a rag around the jaws to keep from marring the mirror housing.
Old Mar 30, 2018 | 12:08 PM
77&79F250's Avatar
77&79F250
I know it is NOT a type 8, I said it looks close to a type 8. And that is just the mirror head part and NOT the mount bracket I am talking about.
Old Mar 30, 2018 | 12:20 PM
NumberDummy
Yes, but the mirror head is also different because the OP's mirror is a gypo.
The genuine Ford TYPE 8 9 1/2" x 6 3/4" mirror head (D5TZ-17723-A) is the same: 1975/96 F100/350 & 1975/91 Econoline.
But the Econoline brackets won't fit an F100/350 properly due to the contour of the doors.
Old Mar 30, 2018 | 03:18 PM
Mech Anon's Avatar
Mech Anon
Are Type 4 and Type 5 hood mount? Those look rad.
Old Mar 30, 2018 | 03:23 PM
77&79F250's Avatar
77&79F250
No hood mount, right below the vent wing on the door.
Old Mar 30, 2018 | 03:37 PM
NumberDummy
No mirror of any year Ford truck mounts on the hood. Type 4's were usually installed on 1961/67 Econolines, but were also installed on 1969/79 Econolines (see upper pic).
Type 5 was the standard equipment L/S manual mirror for F100/350, Bronco & Econoline. But none were factory installed, were placed in the cab at final assembly. because the dealers installed all the outside mirrors.
1000's were THROWN AWAY by dealers, because most people didn't want them.
Old Mar 30, 2018 | 09:46 PM
1TonBasecamp's Avatar
1TonBasecamp
By the way ty.Harris, that's a bitchin' looking truck!
Is that a factory color for your year? Looks kind of like a Ford color, but maybe a little off for being newly sprayed. Looks wonderful, no matter what it is though.
Good luck with the mirror thing. It deserves the best!
Paul
Old Apr 2, 2018 | 07:14 PM
ty.Harris's Avatar
ty.Harris
Sorry y'all, I don't check my email and the weather in Ohio is crazy. Woke up to snow this morning and it's suppose to be nearly 70 tomorrow. But thanks, the pictures make it look waaaaay better than it actually does. It's still a beat up truck, just a little prettier, but no it's not factory, it's coastal blue single stage from summit racing
Old Apr 6, 2018 | 07:09 PM
black & blue 78/9's Avatar
black & blue 78/9
Mirror mounts
The bolt holes in the door skin. Are they the same spacing between a type 7 and type 9. I have type7 on the pickup but would like the type 9 instead.
I have 2 sets of type 9.
Old Apr 6, 2018 | 08:05 PM
1TonBasecamp
You keepin' both sets? Nod nod, wink wink...
Good question though. They do look pretty close. I had Type-8's though, so measuring mine won't do any good. Plenty of 9's around here though. Someone should have that dimension for you.
Paul
Old Apr 7, 2018 | 12:11 AM
NumberDummy
No.
I have type 7 on the pickup but would like the type 9 instead.
1973/79 F100/350: There are SEVEN different TYPE 9's.
See parts catalog pic: D4TZ-17696-A has flat brackets and a different span between these brackets than D6TZ-17696-A that has curved brackets.
D7TZ-17682-A has a slightly different span than these 2.
I don't know what the spans are for the other 4, as the parts catalog doesn't say.
Click on the pic twice to enlarge it, use the cursor to move it around.
