Break Lights Not Working
Old Mar 25, 2018 | 08:51 PM
Casey Hope's Avatar
Casey Hope
I have a 75 f-250 and all lights on my truck work healight,turn signals, and park lights exept hazards in the back and break lights for some reason. Any help would be appreciated.
Old Mar 25, 2018 | 09:07 PM
75BigBlock's Avatar
75BigBlock
Have you checked fuses and flashers?
Old Mar 25, 2018 | 09:43 PM
Casey Hope's Avatar
Casey Hope
Fuses are good but front flashers work but back do not.
Old Mar 25, 2018 | 10:03 PM
75BigBlock's Avatar
75BigBlock
Ok. My 78 Bronco had an issue where all the lights worked except the brake lights and it was a fuse. I had a guy pull up next to me to let me know they weren't coming on. The fuse looked ok, but when I replaced it they started working.
When you say the front flashers work and the back don't, do you mean just the hazards don't flash in the rear or the hazards AND turn signals in the rear? BTW, this is what I mean by "flashers".
Old Mar 25, 2018 | 10:07 PM
75BigBlock's Avatar
75BigBlock
I'm also assuming you've checked the bulbs and that they're good and have both filaments working.
Old Mar 25, 2018 | 10:17 PM
Casey Hope's Avatar
Casey Hope
Oh sorry both flashers work I'll change the fuse tommorow when the sun is out and let you know on that. Hazards don't flash in the rear ,turn signals work though, and the bulbs are new.
Old Mar 26, 2018 | 09:31 AM
Casey Hope's Avatar
Casey Hope
After changing the fuses in the box the break lights still don't work.
Old Mar 26, 2018 | 11:49 AM
HoustonDave's Avatar
HoustonDave
Check your socket grounds to the truck and make sure you have good grounds in the sockets. Most electrical gremlins come from bad grounds.
Old Mar 26, 2018 | 01:22 PM
Casey Hope's Avatar
Casey Hope
Cleanded them with a wire brush and still nothing.
Old Mar 26, 2018 | 01:37 PM
Filthy Beast's Avatar
Filthy Beast
With the new bulbs in and clean pigtail and frame grounds, have a helper stand on the brakes whist you use a test light using it from the pigtail socket to a good ground. Wiggle the bulb a bit when doing this, too.
Does the test light come on?
Old Mar 26, 2018 | 01:41 PM
dlburch's Avatar
dlburch
just for clarification:
do the left and right rear turn signals work individually?
when you say rear hazards don't flash, do you mean they light up but don't blink, or they never light up??
Old Mar 26, 2018 | 02:22 PM
Casey Hope's Avatar
Casey Hope
Hazards in the rear never light up and left and right turn signals are working individually.
Old Mar 26, 2018 | 02:47 PM
Casey Hope's Avatar
Casey Hope
Nope did not come on
Old Mar 26, 2018 | 03:25 PM
hickory1991's Avatar
hickory1991
Have you checked the brake light switch to make sure it hasn't moved, getting power, or for power leaving switch to taillights. If power is leaving brake light switch start following wires back to taillights checking periodically to find where power stops. Check the pigtail on the rear harness for power to brake lights.
Old Mar 26, 2018 | 04:04 PM
Casey Hope's Avatar
Casey Hope
After doing that I am getting constant power from the hazards/emergency warning switch. But why would that not make the break lights turn on? It kinda makes sense but also doesn't.
