- Fitting newer factory wheels
- Carb choke linkage - broken, where to get
- lookn for rims
- Need advice for a swap on a 79 F600 Rollback
- Gas pedal "jumps"?
- Late model wheels....
- Swap to a 83 300?
- Looks like Joe got new stock
- help with the VIN on a 78 Ford
- Explain transmission modulator, kick down, and safety switch
- For those looking for a supercab
- 1979 F350 4x4 one owner
- Engine Swap
- Possible to use a newer box?
- What is the best carb?
- Warner T-19 gear ratios?
- driveshaft question?
- 78 f100 project
- Cleaning your Speedo - Don't do what I did
- 1978 f100 project
- trans whine
- Which brake booster and master cyl to use?
- In-box spare tire holder
- Gauge Cluster Lens - Will it clean up???
- need running gear!
- weight???
- brake swap
- front driveshaft
- my frankenstien
- 1975 F-250 Custom
