- what oil to use for a 1981 custom f-100
- Electrical Failure?
- new menber
- 1981 F250 XLT 4x4 3/4ton - what engine?
- Vent Removal? Cab smells BAD!!!
- water pump mounts to?
- Changing Cabs on my '86 F-250 4x4
- having trouble with charge from alternator to battery
- what the heck is it ???
- Finally! A Reason for that damn "31" code
- Heavier springs for the F-250LD
- 84 f150fuel pump/guage - engine bogs when increase in speed
- Replacing Clutch
- 86 f150 xlt lariat, can't find parts (side-trim, badge)
- Alternator Problem?
- > HELP Ford F250 Diesel Engine
- 5.8L 4V H.O. running rough
- 86 f-150 extcab 302
- taking the bed off
- Started engine, now hear grinding sounds!
- f150 tailgate
- Changing transmission fluid
- Fuel pumps can't keep up?
- Which gear do I have, which gear SHOULD i get?
- Restoring 1982 F150 XLT
- 1986 f150 5.0 4x4
- Paintin my flare
- Do I have the symptoms of a bad thermostat?
- I'm checkin' out an 85 F-150....
- rear end ID tag
