well i just got a 1984 F 150 4x4 4.9 6 cyl. 4 spd stick. i found the tag on the rear end. more confused now than ever. thought there would be only 2- 4 didget # boy was i wrong. got # all oner the place . this is what i can make out. its rusted up a bunch. here goes WOR C 3J08 also upside down from other #'s are 08 8S806A
is the code for the gear ratio on it ?
The second line that starts with 08 - there's a three before that, so you have a 3.08. If there's an L before the 08, it's limited slip, if it's a space, it's open.
thanks for all the help. thought ratio was high. can run 70-75 with no trouble engine not reving up much at all. kind of like to put in 3:73 or 4:10 in ot with 34 X 9.50 15" LST on it sound good? 90% road 10% off road. or less gearing this is a DD
