taking the bed off
Old Oct 10, 2004 | 03:33 PM
bob_002500's Avatar
bob_002500
taking the bed off
i got a 84 f-250 im trying to take the bed off and i had hell braking the bolts loose it bent my cheader pipe but now that i broke them off they just spin and do not come off? is their a bolt on top or what
Old Oct 10, 2004 | 04:16 PM
Karellen's Avatar
Karellen
they should be carriage bolts you probably didn't brake them they most likely rounded the hole
Old Oct 10, 2004 | 05:16 PM
big hoss 29's Avatar
big hoss 29
If you rounded the holes out, you could try a little trick I've used. I took some cheap sockets from a parts store, yard sale, etc. I welded them to the tops of the carriage bolts and that allowed me to use a 3/8 ratchet on top to either hold or turn the bolt while a friend loosened the nuts underneath.
Old Oct 10, 2004 | 05:20 PM
bob_002500's Avatar
bob_002500
where r the carriage bolts r the in the bed?
Old Oct 10, 2004 | 05:23 PM
big hoss 29
Yup. there are 6 or 8 of them and they have a rounded head.
Old Oct 10, 2004 | 07:53 PM
proteks's Avatar
proteks
If the bolts are removed.. could the bed be moved back about four inches?
Just need enough room to beat back the deformation near the cab then slide it back into place.
Are there wires or brackets need to be removed first?
Maybe gas line?
Old Oct 10, 2004 | 08:43 PM
big hoss 29
You will have to disconnect the tailight wiring and the fuel filler necks. You can move the bed back as for as you want, but you will have to disconnect those things first because if you don't, it will hang up the whole project.
Mikemusial
Sep 27, 2014 10:21 PM
48prerunner
Aug 15, 2013 05:06 PM
Tdog71
Aug 11, 2013 08:23 AM
projectbad78
19
Aug 13, 2008 06:02 PM
irishguyincc
1983 - 2012 Ranger & B-Series
Mar 5, 2006 05:22 PM
