Heavier springs for the F-250LD
I have an 84 F250LD and need more leafs on the rear. Currently it has 3 leafs then the straight "overload" helper spring. My 7800# trailer squat the rear pretty bad even with the torsion bars in the equilizer hitch. Don't want to put any more tension on the torsion bars, traction problems.
Would springs from a heavy duty F250 fit? Is this advisable? If so, what years?
As long as you keep in mind that all the springs in the world won't change the capacity of the rear axle bearings I would recommend you condsider adding airbags to the existing suspension. The infinite adjustability could give you the rearend lift when you need it and a decent ride when you don't.
Roger
Roger
