- oil pressure sendor?
- Quick question
- 4x4 electric shift to manual shift
- misses at 1500 cold Rpm
- fuel filter bowl drain valve
- jasper trans croaked
- Rusted brake line
- Changed fuel filter (pic) is this bad?
- starting probs sometimes
- Electric Water Temp Gauge
- Previous post transmission temp incorrect
- How to remove HPOP Lines?
- Turbo Charger Manifold
- boost pressure down
- Street Race Update
- Posi Rear End
- read the codes... can someone translate??
- GPs Test
- Stumble under hard throttle
- Cut off the muffler and cat?
- Water in Stacks?
- need few sugestios please
- Just seeing if i'm where i am suposed to be
- Gold Antifreeze - Green Locktite
- Leaking valve cover gaskets
- Isn't there another fuel filter
- Stumbling, Heavy accel check engine light
- Dumb Questions DP Tuner
- Design A New Exhaust System
- Outside of front tires wearing WHY??
