- 01 dually shocks
- steering shaft firewall seal?
- E99 hydra installed, truck dies in gear
- Many Codes - Order of Operations/Diagnostics?
- time to rebuild!
- Frankenstinky's (and FTE's) bucket list.
- Dana 50 Unit Hub Findings
- Anyone care to help interpret my HPOP numbers?
- Tapping into Power
- 7.3L Missfiring (updated)
- Van Turbo Question
- starter depth engagement?
- 1999 F350 7.3 Powerstroke has coolant in oil and NO oil in coolant
- ZF6 - Roll Pin Size
- Accelerator pedal assembly
- Another hard start (summer time) saga
- Severe High Oil Temps, Low Boost, Flat Power
- Buzzing noise coming from Serpentine belt area when pressing on brake pedal
- New to diesel oil change questions (overfill concerns)
- OEM Fake?
- Viton Torque Converter Hub Seal
- UVCH odd ohm readings and behavior
- Can installing a chip cause a PCM to get fried?
- Shell Rotella T6 $10.98/Gallon @ Pep Boys After Rebate (Limit 2 Gallons)
- "Stinky Spike" on Early 1999 7.3 P1282 after a hard pull and deceleration.
- Battery Harness replacement
- 99 F250 4x4 Bully Dog 3... Truck has no power rough at idle
- Parking Brake Pedal Assembly Refresh
- Required vehicle sticker in door?
- Vacuum and the Knuckles
