i had a problem with my fuel tank. when i changed out the filter it looked like rust. i just put my 3rd on in since ive owned the truck. bout 3 years. none of them looked like that.
Salty
wow that sucker is bad..i change mine every 5k with the oil...in the winter months up here we have a lot of waxing problems with fuel filters when it gets 30 to 40 below with out the wind.. so its a habit to change it often..
Along those lines, how often do you change? Manual says 15k for towing service but after reading stuff about injector costs I'd figure it's cheap insurance to change more often...
Where do you get your filters from? I bought this time from the stealer and it was $$$$$...
i always run a wix up on the moter ..on my peter built i drive i run wix if i cant get a baldwin..i just got the in tank pre pump filter kit from itp with 3 baldwins filters..2 extra...there about the only 2 filter brands ill buy for diesel fuel..
Last one i changed looked like that with 7k miles on it. I had gotten some bad fuel, and being the second time- it broke the camels back. I did the hutch mod. I used to change my filter every 10k, but from the info I have gotten, I should change them both anually now.
My cousin just changed fuel filter out of his 97 F350 PSD and that thing was slimy black!!! Kinda like it was an oil filter....his mpg went up a good 4+ since then.
