- Which models have Cats? Which don't?
- losing power
- oil leak from oil filler pipe not hpop?
- Curious about Wicked Wheel install, still under warranty.
- How much smoke is just smoke?
- speedo recalibrate
- White Smoke Engine Miss
- auto tranny shift sequence...?
- What type of fuel mileage is typical?
- Gearing.......I dunno!
- Clicking noise only on hard launch
- Where is the CPS
- Coolant filter
- Burned up rear axle !!
- SuperChips High perf is gutless problem
- Where to get connector?
- 99 F-350 Won't Start
- Used CPS
- 99 PSD leaking coolant
- Cracked Block or Head?
- Air Filter Maintenance tips
- Wiring
- Leaking front left axel
- Stack Heat
- Talked with Ford Serviceman about Kwik Filter
- EBPV Brake
- Stock down pipe
- TS Performance chip
- Tranny serv
- preditor
