View Full Version : 1999 - 2003 7.3L Power Stroke Diesel
- Do I NEED a 4" exhaust? (Updated, need help!)
- I want a over the axle exhaust but cant find...
- interesting plug found on truck, need help locating jumper cables for it
- interesting plug found on truck, need help locating jumper bacles for it
- 3K miles from home/strange issue with truck
- 7.3L occasional rough running, got AE, what's next?
- steering is no bueno
- what clutch kit to get?
- CA SMOG Problems
- Oil leak
- Scanguage II map sensor?
- DPC-402 XLE4 has given up the ghost. Update: DPC-422 installed. e99 ELC coolant discussion also.
- Stolen truck, can't start it up...
- Should radiator cap hold pressure?
- 360 Thrust Washer for Stock Housing?
- Towing Mileage comparison
- Power steering pump replacement
- 2000 F350; 2 different automatic transmissions?
- Towing with turbo master wastegate
- white smoke on start up?
- 2000 7.3 misfire moniter reset
- 7.3 EX, pre sale inspection
- Early 1999 Torque
- Crank, start, and die.
- Workin' my hide off on the truck today.
- replacing elec lock on pass rear door on crew cab.
- 2000 Turbo Exhaust Housing Gasket
- fuel line from regulator
- Driving Lights/Off-road lights
- 7.3L Idling/running rough, no power
