- Exhaust Manifold Temps, Your thoughts
- Back Pressure valve
- just got my FTE T-SHIRT
- Went to change the oil and... $#&%@*
- Power Steering Issue
- Cold Starting
- compressor surge.
- Aftermarket Exhaust/Straight Pipe [causing flickering check engine light?]
- need new starter
- International Part # for Valve cover gasket
- Help, Truck on side of road dead!
- exhaust manifolds
- Stock but seems weak?
- Brake service time for 02 4x4
- what is the best mods for the money
- Aux Fuel Tank
- What are "Normal" Gauge Readings?
- 6.0 Spearco is installed
- Engine oil cooling
- Camshaft position sensor
- No start problem
- Pms?
- RCM Location?
- Deep Pan Confusion!
- Wastegate question
- Dim Headlights
- EGT Probe?
- what upgrades are best for 2001 f350 7.3??
- Cutting out
- Swapping an AFE stage II for 6637
