- Oil Leak...Pull Engine Or Just Drive It?
- 6.9 C6 to E4OD
- Cooling Issues Continued
- Banks Downpipe Question
- 3" V band factory turbo
- new to diesel
- Belt Tensioner
- I finally got a turbo! Now for questions...
- need a little help here
- Oil Leak Passenger Side
- Idit injection pump in a n/a
- Cruise control parts???
- Replacing ZF5 4WD Tailhousing: Gas and Diesel the Same?
- 7.3 idi turbo diesel skips bad uses oil
- Mystery surge in rpms?
- What is plug c109?
- VEry little pedal travel
- Cracked Injector line or Bad Injector threads
- What should stock turbo pressure be
- water/methanol injection on naturally aspirated
- Occasional Wait to start light
- Sticky Parking Brake
- fuel return question
- Fuse box 1985 F-250 6.9 Where to buy one
- My 1990 f250 7.3s windshield wipers won't work... they don't even attempt to cut on
- White smoke out of tail pipe on fresh rebuild
- 6.9 chuffing in the intake
- 7.3l injectors in a 7.3l turbo
- Difference in IPs from R&D
- 6.9 IDI Starting/ Idling issue
