found a funny heaven
Old Jun 11, 2011 | 12:34 PM
flipklos's Avatar
flipklos
I stopped by my father inlaws place last night and he said his friend wanted to get an old bus going. So I call the guy and find out its a 59 F600 school bus. Ok, Its a yblock V8.
So I swing by to see if the motor is turning (it was) and look around this guy has 5 Y powered trucks and three flattie trucks.
36, 38, 40, 56, 58, two 59s, and a 60!
If you are a fan of tractors as well he has a AC monarch crawler three JD Rs, an LA John Deere, and alot more.
He started one of the Rs for me.
What a funny heaven.
Old Jun 12, 2011 | 11:23 PM
flipklos's Avatar
flipklos
Got the engine to turn with the starter, got spark coming from the coil. Lots of ignition and ground shorts. The plug wires are out of a mechanics nightmare. the coil was shot but the points and rotor were nearly new! Bad rotten ground cable and there is a short between the ignition switch and the coil somwhere. My multitester was dead and I did not have a 9V so I was stuck with a test light. Set them at .016 as a field setting. Does anyone know what the points shold be at on a 1959 F600 292?
I got a set of wires and plugs coming and will rebuild the carb which was full of nice powdery lead. Literaly full.
Old Jun 13, 2011 | 07:24 AM
46yblock's Avatar
46yblock
The point gap is .014 to .016.
turbohunter
Sep 13, 2011 05:30 PM
55 Bus
Sep 24, 2010 04:19 PM
b600jake
New Member Introductions
Sep 4, 2007 06:17 PM
tacson
35
Dec 27, 2006 10:08 PM
Moulder
Sep 8, 2003 01:22 AM
