[Transmission] C6 w/4WD
Truck: 1978 Ford F250
Hey guys, hoping for a bit of advice for this nooby.
I inherited this truck and sadly it's dripping transmission fluid onto the exhaust. I checked the fluid and it's a little on the low side.
So what I want to do before driving it around again, in order to make it leak in hopes I can see where it's coming from, is top off the fluid.
According to my Haynes book it says that I should use "Dexron III or Mercon automatic transmission fluid."
Reading around it seems that Dexron was made for GMC and Mercon was developed by Ford. I'm looking at the website for the autostore and it looks like Mercon V is all that is available.
I also am not comfortable assuming that the fluid I have in the transmission is Mercon. So I'm concerned that I may mix fluid types and cause problems.
Any advice would be great. Thanks in advance.
-Paul
-Paul
Ya, I made a mistake. Meant to put C6. It's V8, 460.
Wonder if that '78 C-6 has ever been rebuilt?
I offer this from an industry paper on transmission fluids.
See if that number is on your dipstick. The Type CJ and the later Type H are no longer available and replaced by Mercon. Any trans that has Type CJ (looks yellowish) in it can use Mercon, Mercon V, or DexIII/Mercon.
If it was rebuilt, likely it has already been filled with Mercon at least.
More reading : Martin Lubricants Technical Service Bulletin ? Transmission Fluid Guide
In 1977, Ford’s first friction-modified transmission fluid, ESP-M2C138-CJ (Type CJ),
was introduced. This was followed in 1981 with an improved fluid with better friction
characteristics, ESP-M2C166-H (Type H) fluid. 76 Super ATF or 76 Multi-Purpose
ATF are recommended for transmissions specifying Type CJ or Type H fluids.
Is the Mercon a clear/red?
gthbryce
04-12-2009 03:42 PM
Ford5.4L
06-14-2006 05:39 PM
joe btrucks
07-19-2002 12:41 PM
