Fuel sending unit
Old Oct 31, 2016 | 08:48 AM
bradphx's Avatar
bradphx
Fuel sending unit
hello guys. Happy Halloween firstly. Secondly I am attempting to install an after market sending unit but it requires screws to hold it in when the original is held buy a circular retainer. Has anyone upgraded their unit and found a way to handle this? I'm very confused on what to do. Please help. Thank you
Old Oct 31, 2016 | 09:22 AM
84espy's Avatar
84espy
I'm assuming that you are going with an aftermarket gas gauge and the sending unit came with it? If so, I would contact that company and see if they have the screw on style sender. If they don't, I would recommend the gauge that can operate with the sending unit you have. I don't recommend drilling into the top of the tank. Not because it's a gas tank, but for leak purposes.
Old Oct 31, 2016 | 12:13 PM
bradphx's Avatar
bradphx
yes I am installing aftermarket gauges. I don't what I'm going to do but I gotta figure it out soon. Need my pick up back. Can't take the motorcycle everywhere during winter.
Old Oct 31, 2016 | 01:59 PM
Derfus's Avatar
Derfus
Have to tested the gauge with the old sending unit?
Old Oct 31, 2016 | 04:46 PM
bradphx's Avatar
bradphx
Yeah. The ohms were different. Caused me to run out of gas ha. It's funny but not funny.
Old Oct 31, 2016 | 09:24 PM
PapaBearYuma's Avatar
PapaBearYuma
If the ohms were low, maybe you could wire in a resistor?
Old Nov 1, 2016 | 12:15 AM
84espy's Avatar
84espy
As an example, I installed an Equus gas gauge. I had to buy the model compatible with the Ford sending unit. Are you sure this isn't an option with your gauge?
Old Nov 2, 2016 | 02:38 PM
bradphx's Avatar
bradphx
well I found a fix. Speedway motors has an item called a fuel gauge interface module. Basically it's a translator for ohms. Here is a link to the part.
http://www.speedwaymotors.com/Fuel-Gauge-Interface-Module,66534.html
Old Nov 3, 2016 | 01:10 AM
84espy's Avatar
84espy
Fuel Gauge Interface Module - Free Shipping @ Speedway Motors
Yeah, I bought one of those also. Mine is to correct the constant bouncing of the gauge needle.
Old Nov 3, 2016 | 11:12 AM
bradphx's Avatar
bradphx
Was it fairly easy to install?
bradphx
Sep 26, 2016 12:43 PM
my 66
Jun 18, 2014 09:59 PM
82fordowner
Sep 2, 2013 07:37 PM
davewave649
Aug 22, 2012 03:27 AM
jrazky
Feb 1, 2006 11:26 PM
