OK I found the vin# thread got most of the info BUT as far as the production # I can't seem to make sense of it. My truck is an F-100 2wd and the serial # is....F10HCX92866. I am I reading something wrong or is this a screw-up? The frame is from a 77 and the cab has been replaced. I don't know where my Dad got it or what year it could be. The ownership is where I got the Vin #. Door plat is gone also
The frame is from a '77. The 1977 model year serial numbers go from X80,001 to Z25,000, yours is X92,866
Probably be a good idea to check the VIN that's stamped in the frame to verify. Top passenger side frame rail, somewhere between the radiator support and firewall, usually inline with the alternator.
You can get replacement warranty plates (the metal plate on the driver's door) from Marti Auto. http://www.martiauto.com/
