Bad Starter and cannot remove
Old Oct 29, 2016 | 11:37 AM
Kyle Wood's Avatar
Kyle Wood
Hey guys i have a 78 F250 400 "m" with the C6.
the other day i hopped in my truck and started her up but since the choke is messed up it died on me (usually keep foot on gas to prevent this). Well i then started her up again and it sounded like the starter got stuck and couldnt spin (it would just click like gear lash i suppose) so i hopped out got a rubber mallet and hit the starter a few times to see if i could wiggle it free. Hopped into the truck, turned the key on it off, and it eventually worked its way free and started the truck up although it sounded like it was grinding badly. It has never done this before up until now.
Yestarday i attempted to remove the starter. one stud with a bolt ontop, and a bolt on the bottom. I can wiggle it but cannot get it to pull out. I have looked up new starters to make sure i have all the bolts out, which i do. Anyone have any ideas why it would all of a sudden make the grinding sound or how to pull the starter out since it is stuck?
Old Oct 29, 2016 | 11:42 AM
good to doo's Avatar
good to doo
Well it,s probably been in there for a while. Take a pry bar and it should wiggle free.
Old Oct 29, 2016 | 11:45 AM
Justin73supercamper's Avatar
Justin73supercamper
I had the gear and bushings come apart in the end of the starter the bendex I think is what it is called. Anyway the pieces got stuck between the flywheel and where ever else the ended up. It took me under the truck and my dad from the top side with Pry bars working the starter out. And make sure the inside of the bellhousing is free of debris before you put the new starter in
Old Oct 29, 2016 | 11:48 AM
Kyle Wood's Avatar
Kyle Wood
Thanks for the quick replies guys! like holy **** lol. What else could be causing this issue? if anything
Old Oct 29, 2016 | 02:42 PM
DB429SCJ's Avatar
DB429SCJ
The top bolt goes in through the bellhhousing and threads into the starter.
Old Oct 29, 2016 | 07:22 PM
Kyle Wood's Avatar
Kyle Wood
So i just got back to checking this and i realized that the top bolt is threaded into the starter.... i thought it just slid off haha oops. Well anyways took me awhile but i got the darn thing out pretty easy once i figured out that top bolt is threaded.
What a pain in the *** location. You have almost no hand room or any room to move a wrench. I am deffinately not looking forward to putting the new one back in.
Turns out i managed to break teeth off of the starter. However, my flywheel looks fine all the way around ( Thank god!!!).
Next question is, how do i get the broken teeth out? or should i even worry about them? My plan is to pull the engine within the next few months, however i just need a location since i dont have a garage
Old Oct 30, 2016 | 01:22 AM
redcreekauto's Avatar
redcreekauto
There should be a small inspection plate at the bottom of the transmission bell housing. A small magnetic wand may fit in to search around for the missing teeth. You want to get them all out otherwise they could cause damage to the new starter and or flex plate.
Old Oct 30, 2016 | 04:58 AM
duste's Avatar
duste
I long extension and a 1/2 inch swivel socket make getting to that one pretty easy. I have seen newer starters actually corrode and swell in the starter mount on the bell housing. Creates a WTF moment the first time you run into it.
Old Oct 30, 2016 | 09:15 AM
PapaBearYuma's Avatar
PapaBearYuma
Actually, the starter is pretty easy to remove/reinstall until you get headers!
Old Oct 30, 2016 | 11:11 AM
Kyle Wood's Avatar
Kyle Wood
There is alittle opening at the bottom of the bell housing (just going off memory so might be wrong location). I can see the flywheel but deffinately dont think i could get a magnet in through there. Is this the inspection area that you are talking about or do i actually have to remove a piece of metal?
Old Oct 30, 2016 | 11:18 AM
krazyness's Avatar
krazyness
Don't know about the 351/400 but on the fe in my 76 I have to remove half of my passenger side header to get the starter out...
Old Oct 30, 2016 | 12:13 PM
duste's Avatar
duste
You said a lot there, I had to take a starter apart, put the front in place then bolt on the body in order to get around the headers , getting it out was even worse, had to back off the tranny bolts.
Old Oct 30, 2016 | 12:35 PM
redcreekauto
Typically but I am not certain of this there is a small section of the plate between the transmission bellhousing and engine block that can be taken off by removing two bolts. On your truck I am not certain.
Old Oct 30, 2016 | 11:14 PM
PapaBearYuma
My 351m/C6 has an access panel on the front of the bell housing for the torque converter bolts. It's about 5" wide and 2.5" tall, and is secured with two screws-3/8 hex head
The panel is bottom center of the bell housing, in the plate that separates the engine from the transmission, and faces the front of the vehicle
There's very little clearance inside
78Ranger_GARedNeck
Dec 8, 2008 08:51 PM
r_reed
Dec 12, 2006 10:25 PM
RAMPAGE_F350
Dec 6, 2005 06:30 PM
mnbf
Bronco II
Nov 2, 2005 07:28 PM
yoda
Jan 19, 2004 03:27 PM
