new brake issue
Old Apr 30, 2007 | 05:16 PM
StarTrash's Avatar
StarTrash
new brake issue
i have a new brake issue...i changed the brake booster ok that quit the suckson sound..and i bleeded my brakes..but my pedal builds once and after that it dont get any better and its like 2 inchs from the floor..my back brakes the fluid while bleeding shoots out like it should but the fronts kinda just slide out but a steady stream no bubbles or anything..i changed the hose from the brake booster to the engine same issue with everything...anyone got any ideas?...please and thank you.
Old Apr 30, 2007 | 05:35 PM
Mil1ion's Avatar
Mil1ion
Did you adjust the booster pushrod length properly ?
http://www.clubfte.com/users/mil1ion...trations2.html
are the rear brakes adjusted properly ?
Old Apr 30, 2007 | 06:19 PM
StarTrash's Avatar
StarTrash
thanks for the diagram.. how do i adjust the booster pushrod?
the rear brakes are auto adjusters..i havnt done the adjustment process on them yet
Old Apr 30, 2007 | 06:53 PM
TG28's Avatar
TG28
before you can rule anything out , you need to get the rear brakes and the pushrod adjusted correctly, I learned the hard way and wasted alot of effort
Old Apr 30, 2007 | 07:54 PM
Mil1ion's Avatar
Mil1ion
Don't settle for auto adjusters..do it manually to make sure.
The drums should Just barely scuff the shoes.
to make the pushrod adjustment. cut a piece of metal or hard cardboard to make a slot out of it equal to the measurement required then set the length according to that.
Old Apr 30, 2007 | 08:00 PM
rusty7983's Avatar
rusty7983
yeah, sounds like your rear brakes need adjustment.
Old Apr 30, 2007 | 08:21 PM
StarTrash's Avatar
StarTrash
ok thank you all
