Automatic to 5 Speed Conversion
Old Dec 31, 2017 | 12:12 PM
LipRipper3006's Avatar
LipRipper3006
I have a 1980/81 F-150 4x4. Has an automatic behind the 351 M, soon to be 4BT Cummins. When I do the swap I am not leaving the auto, looking for fuel economy above other things.
I have heard that some of the 87-96 Ford Trucks have ZF5 transmissions that will be compatible with my application, can someone confirm that this is true? I am looking to make as little modification as possible. Will a ZF5 from one of these trucks bolt to my transfer case and engine like it was factory? The 4x4 shifter comes through a plate on the floor. Will a floor plate from 1980-1996 F-150 with the 4/5 speed 4wd cutout work with my truck?
Is the hydraulic a good thing to buy from a junkyard or just buy one new? What years of clutch pedal assembly will work in my truck? (80-86?) Anything else I need to consider? (Gas vs Diesel Trans?)
Old Dec 31, 2017 | 09:14 PM
Franklin2's Avatar
Franklin2
I will assume you are going to get an adapter for a Ford setup for the 4bt? All of the 4bt adapters I have seen that were originally used in the bread trucks adapted to a small Ford pattern. So yes, if you get a zf from a f250 that had a 300 six or a 351w, it should bolt up. And it will also bolt up to the transfer case. You may be able to find a zf in a f150, but they are not as common.
If you need the pedals for your truck, you will have to use the pedal assembly from a 83-86 truck, any engine will work. The slave cylinders are different though, but I am assuming will be be buying a new one of those. 87-up pedals will not fit the 86-dwn trucks.
Old Jan 1, 2018 | 07:57 AM
Eddiec1564's Avatar
Eddiec1564
2X on that. 87 and up pedal brackets and clutch master cylinder are different and will not mount into the 86 and older trucks.
As for using junkyard clutch hydraulic parts, I would not use the internal slave cylinder if the transmission has it. Would sux to repull the tranny to replace it. Now if you have the external slave cylinder, I'd go for it....
Old Jan 2, 2018 | 07:08 PM
LipRipper3006
Will the transfer case from the c6 bolt to the zf5 along with the linkage or will i need a t case to go with the zf5?
Old Jan 2, 2018 | 07:55 PM
whisler's Avatar
whisler
The C-6 transfer case will bolt to the ZF. Whether the transfer case linkage will work depends on differences in length of the transmissions, I believe.
Old Jan 2, 2018 | 07:57 PM
Nothing Special's Avatar
Nothing Special
I've always heard that Ford transfer cases are all interchangeable, at least from '80 - '96/7 (and maybe even a lot farther than that). But just this evening someone started this thread on the '87 - '96 forum saying that there were some differences. So now I don't know how to answer that.
Old Jan 3, 2018 | 05:01 AM
Franklin2's Avatar
Franklin2
They all bolt up to the different trannies. But they are correct, there are shifter differences and some have a slip joint output, some have a fixed yoke output. But if he is keeping his old transfer case, he should be OK. There is about a 1 inch difference in length.
Old Jan 3, 2018 | 11:57 AM
Nothing Special
The OP in that thread claimed that putting a t.case from a '92 E4OD onto a '94 ZF5 didn't work because "its mating surface diameter is smaller than the ZF adapter surface leaving about 0.5" step open to the cavity between the tcase and transmission".
I can't picture what he was seeing, and yes, this goes against what I've always heard that all Ford t.cases bolt to all Ford trannies. I'm just reporting what that thread is bringing up.
Old Jan 3, 2018 | 08:53 PM
reamer's Avatar
reamer
The small block ZF configuration only came with the internal slave, you may have no choice.
This is actually a better slave because it works the clutch from the center, its an even Push-pull.
Big Block gas and Diesel ZF's used the external slave
keyul
Apr 23, 2015 09:34 PM
Blued Steel
May 25, 2013 06:17 AM
kensdodge1
Nov 29, 2010 05:22 PM
BBF-350
16
Jul 9, 2008 05:38 PM
OldBrown82
Oct 11, 2007 06:16 AM
