Srod shifter saddle replacement
Old Dec 29, 2017 | 08:15 AM
FirstFord1994's Avatar
FirstFord1994
I can't find anything on replacing the shifter saddle/bushing on this transmission if anyone has done it could you please chime ln is it simple as pull shifter out snap old part out snap new part in or is there a certain procedure to it ???
1981 ford f100 4.9l srod manual trans 2wd
Old Dec 29, 2017 | 12:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by FirstFord1994
I can't find anything on replacing the shifter saddle/bushing on this transmission. If anyone has done it, could you please chime in.
Is it simple as pulling the shifter out, snap old part out...snap new part in, or is there a certain procedure to it?
1981 F100 4.9L with RUG SR-OD Single Rail 4 Speed Overdrive.
7K453 nylon bushing is shown at upper right in pic.
AFAIK, all you have to do is remove the shift lever, remove the broken pieces (a common problem!) of the old bushing, replace with new.
D9BZ-7K453-B (replaced D9BZ-7K453-A) .. Gearshift Dampener Nylon Bushing / Obsolete
1979/82 Granada; 1979/83 Mustang/Capri/Fairmont/Zephyr; 1980/83 F100/250.
Old Jan 13, 2018 | 07:20 PM
FirstFord1994
Thanks for all the help all fixed shifts smooth as butter now
Old Jan 14, 2018 | 07:43 AM
FuzzFace2's Avatar
FuzzFace2
Good to hear you got it fixed but do tell us how as Bill list the part as " Obsolete".
Where did you find a new one or did you make something to "fit in"?
Dave ----
Old Jan 14, 2018 | 07:50 AM
FirstFord1994
Found 1 on eBay just searched srod shifter saddle and it came up
Old Jan 14, 2018 | 02:37 PM
FuzzFace2's Avatar
FuzzFace2
Thanks for answering as it may help others.
Dave ----
Old Jan 14, 2018 | 09:06 PM
FirstFord1994
it was the 1.5" srod shifter saddle i put it in with the square part on the right hand side when you are facing dash hope this helps someone
https://www.ebay.com/itm/SROD-RUG-RT...xVBMSp&vxp=mtr
torquemeister
Aug 26, 2014 10:03 PM
RIDGWAY66
Aug 26, 2010 08:18 AM
89frankenford
Dec 1, 2008 12:30 PM
brown 4x4
Dec 1, 2005 04:01 PM
