No Fuel
Old Dec 30, 2017 | 02:39 PM
LipRipper3006's Avatar
LipRipper3006
No Fuel
1986 F-150 302 EFI
New Tank, 2 new in-tank fuel pumps, and the truck has no pressure at the Schrader valve. Anticipating buying a new fuel tank selector valve will solve the issue. Anyone know where to get 1?
Old Dec 30, 2017 | 04:30 PM
FuzzFace2's Avatar
FuzzFace2
Are they in tank lift pumps that feed the high PSI pump on the frame rail?
A little more testing is needed before you can say it's the valve.
Do you have power at the pumps?
If so and you pull the hoses do you get fuel out of them?
If so where does the fuel stop at?
If at the valve then you are right on needing one but id it goes more then you have to see why it does not make it to the injectors.
Dave ----
Old Dec 30, 2017 | 05:04 PM
matthewq4b's Avatar
matthewq4b
Originally Posted by LipRipper3006
1986 F-150 302 EFI
As noted check to see if you have an on frame pump.
Then check the inertia switch to make sure it is not tripped
Next step is to check the fuel pump relay to make sure it working. Then the fuel tank selector.
Check the easy stuff first.
Old Dec 30, 2017 | 05:42 PM
LipRipper3006
Went to Autozone and bought these https://www.autozone.com/fuel-system...ine/963502_0_0.
Hooked up the rear tank lines to the main line and it fired up and idled like a champ.
Old Dec 30, 2017 | 05:52 PM
FuzzFace2's Avatar
FuzzFace2
Well then maybe it is the valve?
Dave ----
tazzmann01
29
Mar 1, 2020 07:15 PM
NicksF250
Jan 28, 2016 05:37 AM
oldfart
Apr 10, 2012 07:25 AM
LadderCaptain
Jan 3, 2005 11:10 PM
stevegooch
May 30, 2004 05:27 PM
