Power steering filter
Old Nov 6, 2003 | 08:58 AM
thesaintoc's Avatar
thesaintoc
I just installed a power steering filter in my '92 I6 and have not had a chance to feild test it yet. I tried to find the filter that Mustang guy moderator suggested but all I found in socal was a 5/16 tranny filter for $25. My power steering lines are 3/8 so I ended up buying some reducers which made the line too long so I put a longer hose on and looped it so that the power steering return line would not kink.
Anyone out there done this mod?
Old Nov 6, 2003 | 11:35 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't have a filter on my powersteering system. I didn't know they made a dedicated powersteering filter, as I've never heard of a filter on powersteering anyway. It sure can't hurt anything though.
I guess this question is more for MustangGT, but why do we need a filter on the power steering line? I can understand about automatic trannys and engine oil, but there shouldn't be much contamination of the powersteering fluid. I could be mistaken, and I'm all for learning new things, so I'm eager to find out.
Old Nov 6, 2003 | 01:31 PM
gatesj's Avatar
gatesj
Definitely can be contamination but especially if the box or the pump blew. Then there are peices of one stuck in the other. You replace the failed unit and the shavings come back around out of the piece that was fine and that you didn't replace and destroy both the pump and the box. The filter stops the vicious cycle.
Old Nov 6, 2003 | 07:06 PM
EPNCSU2006's Avatar
EPNCSU2006
That makes sense, thanks. But any reason for a normally functioning system?
Old Nov 7, 2003 | 05:37 AM
shuttlevalve's Avatar
shuttlevalve
i just used a tranny in line filter in my wifes 96 explorer after i had to change the rack and pinion , but i let it go to long and now the pump is bad or at least weak it really doesnt have much for power steering now and howls more than it use to.
Old Dec 13, 2003 | 10:44 AM
gatesj's Avatar
gatesj
Well, no reason especially but it can't hurt..
pawpaw
Oil & Lubrication
Dec 4, 2014 08:08 PM
schlepprock250
15
Apr 23, 2011 08:31 PM
cweller
Apr 15, 2011 07:03 PM
cujo8
20
Jan 4, 2007 11:09 AM
Craig5_12
17
Jun 29, 2006 10:54 PM
