Volts go down when in idle
1.) Test Static Battery Voltage. Static means NO LOADS (lights, etc. radios are OFF!) You should get btwn 13.0 & 13.5. Any less than this put it on a charger over night and test again.
2.) With Meter hooked up to battery, turn your headlights on for 1 minute. This will remove any gassing charge from the battery and stabilize it for the rest fo #2. The voltage will drop to about 12.2 - 12.4V DC. Turn headlights off and wait 1 minute. Check voltage again. Should be above 13.3.
3.) With meter hooked up to battery, start engine and let idle. Check yer voltage and listen near the alternator for a whine. If you hear a whine then the alternator is more than likely putting out. If not THEN take it down to shop and have them check the alternator. Check yer voltage. Anything about 13.9 is ok. 14.6 to 14.9 is lots better, but those numbers will not come into play until the engine is revved up.
4.) Rev the engine to about 1500 rpm. Check yer voltage now. It should be above 14.3. -14.5. With NO LOADS!!!!!!
5.) with the engine running, turn on headlights, heater fan, and everything else lightwise and accesory wise you can and run at about 1500 rpm. Your voltage will take a drop but it should stabilize above 12.V. This is good. If it keeps dropping then yer alternator is bad.
If your not having any problems cranking in the morning or getting dead batteries everyother day and the truck runs fine otherwise I'd say your voltmeter is probably overly sensitive. As long as it stays in the NORMAL range you're probably ok. But check those numbers.
Larry
I still get the low voltage reading at hot idle, accessories or not (though they make it just a little worse). The lights dim a little when the needle drops. I'm sure it's the alternator, you bring up the idle just a little and the needle pops right back up and the lights/heater run brighter/faster. So I know it's not the gauge.
I found that the "O" in normal's just above 12 volts and the "L" is a touch above 14. Mine's near the "L" except at hot idle. But who knows if this is the same for all of these trucks.
I know the battery and the wiring is good so it's time for me to rebuild the alternator now.
If you're thinking of just buying a rebuilt alternator, be careful. I've had bad luck (0 for 7) buying the Kragen / Autozone one's. It looks like they sandblast them, put in their rebuild kit, and resell it for 2-3 times the price. The one's you get at Ford for 180 are actually rewound.
This is why at hot idle the voltage goes down below what you would consider normal. In this case it's not a critical problem just one that's more annoying than anything else. This happens in all brands of vehicles. I run a 250V DC Motor Generator Set on a Diesel Electric submarine and when it heats up it takes more DC amps and voltage to run and get the required 60Hz A.C. voltage out the other side. It's normal!
The alternators don't really start putting out amps and volts until about 900-1000 rpms anyway. It will float voltage at idle speeds.
Another analogy is CPU chips on your computer. Guys that are into hardware modifications will cool down the CPU with circulating water, freon systems, liquid nitrogen, and other coolants to enhance the performance of their computer CPU's. HEAT is an enemy to electrical components. Not much in the way of getting rid of the heat in the engine compartment other than airflow, so that's the reason behind the fan on the pulley. The alternator is not as sensitive as a CPU but the premise is still the same. Cool the unit and it will perform to new spec's far longer.
Larry
