Windshield Washer Doesn't Work
Old Jan 6, 2005 | 11:50 PM
HVJ's Avatar
HVJ
Question Windshield Washer Doesn't Work
Sprinkeleren virker ikke når man trykker visker kontakten i enden, viskerene starter godt nok
My sprinkler doesn't start. I tried to connect it directly to the battery and it worked fine. On the right side of the cabin, there is a relay that clicks when I try to turn the sprinkler/washer on and there is a little electronic box that is called the wiper control: is the sprinkler controlled by this too?
How can I check if there is a signal to the washer?
Thanks!
Old Jan 7, 2005 | 04:09 AM
TexasGuy001's Avatar
TexasGuy001
It sounds like your having the exact same problem I did. I replaced the little pump/motor in the windsheild washer reservoir. That fixed the problem for a while. Then after it started acting up again, I cleaned the connector up and sprayed the contacts with electronic parts cleaner. Berryman's makes it. I got it at our local auto parts store. There are probably other companies that make it too. You might be able to get some at Radio Shack or some place similar. If you do this, make sure you give it some time to dry out before hooking it back up. Hope this helps.
