Instrument cluster issue
Old Aug 3, 2005 | 03:54 PM
backhoeken's Avatar
backhoeken
This is a little off topic but could not decide where to post it.
I have a 89 F250 7.3
On the electrical gauge the black "cover" that goes over the light has fallen off and is bouncing around behind the clear plastic of the instrument cluster. Does anyone know of a way to take the cluster apart so I can get the part back on.
Thanks
Ken
Old Aug 3, 2005 | 04:47 PM
quicklook2's Avatar
quicklook2
look in tech section under tach replacement.
Old Aug 5, 2005 | 12:00 PM
backhoeken's Avatar
backhoeken
Went through the section and could only find entries for 92 to 97. Looking for 89. Must be over looking something. Could someone please point me in the right direction
Thanks
Ken
Old Aug 5, 2005 | 02:24 PM
quicklook2's Avatar
quicklook2
i thought that even though yours was a different year that the article would help you out and give you an idea for how to deal with your 88.
Old Aug 5, 2005 | 03:16 PM
backhoeken's Avatar
backhoeken
You are 100% correct it gives a lot of insite and helps a lot, This is what it is all about, but just need a little more and the location of the screws to remove the cluster.
Old Aug 6, 2005 | 11:47 AM
backhoeken's Avatar
backhoeken
The insight was very helpful and convinced me it was an easy task.
Instructions for 87 to 93 for removing the instrument cluster
1- remove the 2 upper screws (located in the top of the clear plastic)
2- remove the wiper and lights ***** (clasp loaded)
3- remove the left bezel (the one left of the steering column)
4- remove the screw holding the right bezel (located under the steering column)
5- remove the right bezel
6- remove the 6 remaining screws that hold the cluster in place
Old Aug 6, 2005 | 02:57 PM
quicklook2's Avatar
quicklook2
did you get the part back on over the light?
Old Aug 6, 2005 | 03:46 PM
backhoeken's Avatar
backhoeken
That was the easy part. A dab of model glue and it was perfect.
ponyman_65
Oct 2, 2014 08:07 AM
genevanvoorst
Aug 26, 2014 05:56 AM
MKPJ1
32
Nov 30, 2012 01:40 AM
hush210
1997 - 2003 F150
Feb 23, 2007 08:37 PM
