OBD II code help
Old Aug 4, 2005 | 06:40 AM
96f-150's Avatar
96f-150
OBD II code help
I have a 96 f-150 5.0 4x4. I bought a code scanner yesterday and it is pulling a "p0401 egr flow insufficient" code. Any help on what to do next would be great.
Old Aug 4, 2005 | 10:58 AM
andym's Avatar
andym
Put a vacuum gauge on the EGR valve. It should stumble when you put some vacuum on it (like 8 inches). If it doesn't, then the EGR valve isn't flowing enough. If it does, then the EVP isn't telling the computer that the valve moved like it did and it probably bad.
There are also procedures for testing the EVP in the haynes manual as well as a good explanation of how the system works.
Old Aug 4, 2005 | 11:18 AM
96f-150's Avatar
96f-150
I just bought a new egr valve at lunch. Any special advice on changing it? Is there any thing else i should look for or do while i have it off?
