testing coil for spark
Old Aug 4, 2005 | 12:59 AM
cbjr61's Avatar
cbjr61
Question testing coil for spark
i took a spark plug wire off used a screwdriver and went to ground when key was turned over no spark.. then i took wire from coil going to distributor off and did same thing. is this the proper way ? so is the coil gone? or is another way to test coil?
thanks
Old Aug 4, 2005 | 05:42 AM
dgeesaman's Avatar
dgeesaman
How much of a gap did you leave for the spark to arc over?
Dave
Old Aug 4, 2005 | 09:16 AM
cbjr61's Avatar
cbjr61
not a big gap how close should i be i was almost touching frame
Old Aug 4, 2005 | 11:42 AM
dgeesaman's Avatar
dgeesaman
I was told 1/4" to 1/2". I'm not sure if you're supposed to start with it close and move it away, or the other way around.
I need to do this test myself on my RX-7, and I too would appreciate some extra details on how to do it without shocking myself or burning up the wires. Anything capable of arcing 1/2" is pretty high voltage.
Dave
Old Aug 4, 2005 | 09:08 PM
cbjr61's Avatar
cbjr61
i retried it but still no spark i am hoping it is my coil it looks easy to change
is there another way to test the coil
thanks
Old Aug 4, 2005 | 09:20 PM
dgeesaman's Avatar
dgeesaman
There should be a resistance across the coil. Check a manual for the value.
Dave
Old Aug 4, 2005 | 10:30 PM
FSC's Avatar
FSC
in most cases, if the spark will jump 1/4 inch, it is considered good,
There are 3 systems to the ignition system,
1, coil, best quick test is to subsitute a known good coil
2. control module, most parts stores will test this for you, you have to remove it and take it to them.
3, stator assy., difficult to test, if all else fails, replace it.
If you have an ohmmeter and a good book, you can do some of the tests yourself.
hacksaw22
Sep 15, 2023 07:47 AM
regarrr
1978 - 1996 Big Bronco
Nov 7, 2008 09:09 PM
threespeed
Bronco II
Mar 6, 2005 06:55 PM
nismo_2
Apr 26, 2004 05:17 PM
