- Need help NOW! Dashboard temperature low (possibly)
- Exhaust preferance
- glow plug times
- street racing
- Overdrive Button
- Front Drive Shaft Problem
- Powertrain Control Module info
- Forgot one thing
- rough idle
- block heaters
- Non-stop fuel leak
- tire pressure ? while towing heavy load
- blowing the glow plug/fuel heating bowl fuse?
- replacing the water pump
- increase air flow
- Exhaust brake
- Decreasing margin of return?
- 5 spd leaking
- A belt that squeaks ALOT.........
- Bully Dog ????
- Fuel filter
- Glow plugs
- Injectors
- Wait to start times
- heater problem
- So why do I need a Boost Gauge?
- Brought block to the machine shop today
- Vibrations @ 65-70
- frustration as usual!
- Low Engine Temp
