- fpr shim
- Coolant Capacity
- going to get intercooler and need advice
- Front axles
- Employee problems....OT RANT
- Fan speed for AC/Heat
- Allison Tranny on a Powerstroke?
- Water temp ?'s
- A/C Lines ??
- Hard starting
- Drivers side loose hub
- Heater mod and which valve to use?
- gooseneck hitch
- r these the right resistors for the idm mod?"they look to small"
- Clutch replacement suggestions?
- New Rim Advice Anyone?
- HPOP O-ring ?
- Glow plugs
- Smoke out of valve cover
- Gauges & pod decissions
- Trans Rebuild, Would you do it your self?
- Up-pipes leaking
- Are rubber collars need on injector connectors
- tranny issues??
- high pressure oil pump???
- Pyrometer Help
- rear diff cover leak!
- Steering shaft question
- Clutch hydraulics - replace roll pins?
- Shake at 40.......
