tire pressure ? while towing heavy load
Old Nov 8, 2007 | 06:57 PM
tndiesel's Avatar
tndiesel
Will be leaving in the morning to go to Valparaiso In. to pick up a load of hay. On the way up I will be pulling a 5K pd. trailer and on the way back I'll pull the trailer plus 10K pds of hay. So 15K pds. total I'll be pulling. I have load E tires in front and back. Fronts are 245s and backs 265s. I don't really know what air pressure to run. I just went to the truck stop and put 65 in front tires and 70 in back tires. Am I too high or too low? Advice is very welcome.
Old Nov 8, 2007 | 07:00 PM
c00nhunterjoe's Avatar
c00nhunterjoe
that sounds good for e's, i run d's at 50 and have no problems
250turbo's Avatar
250turbo
loaded i run 60 in front 80 in back
Old Nov 8, 2007 | 07:17 PM
97-psd's Avatar
97-psd
sounds about right to me, that's what I ran in my work truck and since it was a flat bed I regularly hauled a lot of weight and never had any problems, best of luck on your trip, and don't worry, everything go well and you will be back in God's country soon and you will tell us how well your truck did
Old Nov 8, 2007 | 08:17 PM
Neal 97 250's Avatar
Neal 97 250
I usually put 60-65 in mine when pulling and less when not.
Old Nov 9, 2007 | 06:20 AM
MLCinNCTX's Avatar
MLCinNCTX
Look on the door jam for the tire presure. Mine calls for 50psi in the front and 80 psi rear. I run 60 psi all around except when I am hauling fence material (pipe, t-post, and wire) or hay. I put 80 in the rear. My tires are 235/85/16E.
Old Nov 9, 2007 | 07:30 AM
wmiller's Avatar
wmiller
just look at the side wall of the tire it will tell you
Old Nov 9, 2007 | 02:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
X2 with wmiller. never go more than specified.
bro460
Modular V10 (6.8l)
46
Feb 22, 2009 01:28 PM
tndiesel
Nov 11, 2007 09:10 PM
tndiesel
38
Nov 6, 2007 08:07 AM
tndiesel
23
Jun 16, 2007 07:23 AM
