- Losing oil somewhere
- STARTER PROBLEMS!!!
- 10,000 & Blown Bellows
- Anyone parting a truck out - need some elecrical stuff..
- Front Tank Fuel Gauge Pegged to Empty
- ZF5 Reverse Gear Grinding - any tricks i can try?
- Power Loss Problem Solved - BARO sensor was the culprit
- Extended cab rear seat stuck
- New Truck Woes
- New business venture
- Whats Up?
- UPDATE: Well she runs, but do I now have a bad injector?
- Oil Leak
- Low power sometimes.. think i fixed it
- Clutch Master Cylinder popped out
- Door panels
- vacuum leak?!?
- 1996 starts than dies, help
- Fuel filter issues
- Free turbo, but what is it?
- Looking for shop in Chattanooga
- Running on jet fuel
- Found the problem!!!
- Interior $3450 later
- Tractor Supply Rotella T6 5w40- $18.99
- head studs, etc.
- Valve stem/valve lock questions
- Oil Cooler and Oil In Antifreeze
- Knew it was too good to be true...
- Mods for 96 7.3
